Dont mean to spoil the party but I use regular all the time and have never heard a sputter or pop. Where does it say that regular will ruin the motor?
"Ruin the motor" might be a little strong. The compression or amount of compression the engine has determines (usually) what octane is recommended/required for the engine. By running higher octane you stop pre-detonation from happening. The spark will be the only thing setting off the fuel, not the high temp and compression as the pistion comes up for the power stroke. On some engines, with lots of miles, and lots of carbon/gung build up on the heads, the compression increases and the engine can begin to ping. By cleaning out the combustion chamber that can be corrected. Running the higher octane will keep it from pinging as well. Each engine is a tad different, and like you said you are having no problem, but most can notice a difference between the 87 and the 93 octane. Your driving style and engine mods also make a difference.
I work in the construction trade (steamfitter) and had a job at the loading rack in the largest refinery on the east coast. Its a Conoco/Phillips at this time. It has changed "brands" 4 times in the last 5 years..........
Anyway, every gas truck know to man, yeah Shell, BP, Citgo, Sunoco, etc was loaded at this loading rack. I know, I watched them.
The local gas station contols the octane of the mid grade only. The mid grade is a blend of reg and super
I hate to be the sour grape here but many of you a misinformed on how octane ratings work. Higher octane means it can be compressed more before combustion. This means if your running a stock lower compression engine (I'm pretty sure the stock HD bikes all are lower compression engines, 8.9:1 ) you need to run a lower octane fuel. If your running 93 octane what you get is carbon build up over time and then sticky valves, fouled plugs, etc. Actually running higher octane fuel in a lower compression engine will cause damage, not the other way around.
As far as the guy with access to 100LL. You will damage your engine if you run 100LL in your bike and even if you have HC pistons in your bike go ahead and run it, but make sure you mix it with some auto fuel or pour a couple of capfulls of Mystery oil in with the fuel as a lubricant.
"The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more."
Its your bike and you can run whatever fuel you want, but I thought you guys should know there is some misinformation out there about fuel octane ratings and how they work.
be safe.
Low compression + high heat (air cooled) == need for higher octane.
I'd agree with you if the MoCo said run 87, but they dont.
Compression ratio isn't everything. You can run a higher compression with a lower octane on a liquid cooled motor that has aluminum heads and or block for instance.
Resistance to detonation is what you are going for here.
I think 93 octane is pretty cheap. After building up my last bike, I had to run 100 octane
to make it run right.
LOL That sucked. I'am happy to pull up to the pump on my 06 RK and pay for 93.
