Are you running a stock air cleaner? Is it chirping when you accel? There is a rubber hose that comes out of the back of the air cleaner on a stock set up, on others they plug the opening where the hose comes through.Check your hose or plug make sure its not leaking.It's a simple fix if that's it but will drive you nuts trying to find the noise...
hrhawg is correct. A loose belt will trap air in between the splines and belt while upshifting causing the air to compress after shift and "chirp" as the air is forced out. Belt tension is probably loose. Get worse when wet? Definite sign.
So does this mean his bike is farting or queafing?
