Chirping sound when I downshift
Old Feb 27, 2008 | 06:04 AM
DaveMK's Avatar
DaveMK
Default Chirping sound when I downshift
No, I didn't run over a bird. When I let the clutch out it makes a quik chirp sound. Sounds like something needs to be adjusted. I'd like an idea of what it could be before I take it to the shop.
Old Feb 27, 2008 | 06:30 AM
tanq's Avatar
tanq
Default RE: Chirping sound when I downshift
Are you sure that it's not your rear tire skidding a little bit? How about belt tension? Just a couple of thoughts.
Old Feb 27, 2008 | 06:51 AM
gottahavvitt's Avatar
gottahavvitt
I had a similar problem once and it turned out to be a loose baffle in the exhaust. Tightened it up and the birds flew south.
Old Feb 27, 2008 | 07:06 AM
stro1965's Avatar
stro1965
Take your clutch perch apart and clean it up, lube it with some silicone spray. Also hit the shifter assembly with some spray too. Worked for me.
Old Feb 27, 2008 | 07:35 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Probably the belt. If the tension is OK, try dragging a block of paraffin along the edges to lubricate it.
Old Feb 27, 2008 | 07:40 AM
hrhawg's Avatar
hrhawg
Had that sound show up on a trip. Stopped at the next dealer they adjusted the belt. Chirping sound is typically just a loose belt. Check that first.
Old Feb 27, 2008 | 08:36 AM
choochoo's Avatar
choochoo
It can be numerous things.
Among others above, check your belt tension.
Not the one around your waist, but rather the drive belt.
If in doubt adjust it slightly tighter.
The chirping normally sounds like it is coming from engine.
Old Feb 27, 2008 | 08:47 AM
Geoff's Avatar
Geoff
The sound is the belt. In many cases it goes away over time.
Old Feb 27, 2008 | 08:50 AM
FLHT's Avatar
FLHT
An overly dirty belt will do it too.
Old Feb 27, 2008 | 08:56 AM
BigGeorge's Avatar
BigGeorge
No one has mentioned motor mounts. My sons Dyna was chirping and it was the motor mounts. Sprayed them withWD 40 and the chirping stopped................BG
