08 grips
Old Mar 2, 2008 | 07:22 AM
hdrider268's Avatar
hdrider268
2nd Gear
Default 08 grips
Any advise for aftermarket grips for a 2008 streetglide? Are they easy to change (throttle mechanism)? Thanks.
Old Mar 2, 2008 | 07:30 AM
electaRICK's Avatar
electaRICK
Default RE: 08 grips
I was askin the dealer this yesterday,,, its easy to do, but ya gotta get grips for a 08,,
remember , grips on the shelves now have the throttle tube desinged for cables, wont work???
Old Mar 2, 2008 | 07:42 AM
HOGWYLDPR's Avatar
HOGWYLDPR
I just changed mine on my 08 RG and it's very easy. Just loosen the switch housings and gently pull the old grip off and slide the new one in. Took me about ten minutes.
Old Mar 2, 2008 | 07:58 AM
warthawg's Avatar
warthawg
Just did mine on Friday, needed a little advice from the forum, but all in all was pretty easy:
https://www.hdforums.com/m_2957087/m...tm.htm#2957087
I got the Kuryakyn ISO Grips. Be sure to order the ones for the 08 with ETC (part number 6227). Only real problem was understanding a bright orange WARNING sticker on the packageing:
"WARNING - Please insure that you keep the glue from the throttle open"[sm=WTFsgign.gif]
(yes I typed that right)
Old Mar 2, 2008 | 08:40 AM
Garemlin's Avatar
Garemlin
Simple. I did mine on Friday. Seperate the switch housing and gently pull the old grip off. Slide the new one on and make sure the teeth are enggaged. Slide it under the housing and tighten back up. Left side is as it always was.
Old Mar 2, 2008 | 08:44 AM
Meist21's Avatar
Meist21
Second vote for Kury ISO. I have already switched mine out once. The whole process took about 10 minutes. Just make sure the gears or teeth as I call them are positioned correctly on the throttle side.
Old Mar 2, 2008 | 08:46 AM
Towpro's Avatar
Towpro
ORIGINAL: Monstermile
****, ya'll know it's simple if Steve did it......Rick.[:'(][:@]
Old Mar 2, 2008 | 08:49 AM
Garemlin's Avatar
Garemlin
ORIGINAL: Towpro
Damn that was cold bro.[:@][] I'm not awake enough for a snappy combeack so I'll let this one slide.
Old Mar 2, 2008 | 08:50 AM
hdrider268's Avatar
hdrider268
2nd Gear
Thanks for the help Towpro; Meist21; Monstermile; warthogsf; HOGWYLDPR; electaRICK- keep the shiny side up.
Old Mar 2, 2008 | 08:57 AM
[Hooligan]'s Avatar
[Hooligan]
ORIGINAL: Towpro
LOL......that RON is a funny guy!
