vibration problem
Old Mar 3, 2008 | 06:22 PM
MR. SCOOTINN's Avatar
MR. SCOOTINN
Default vibration problem
i have a engine vibration which was not thier before,,,brake peddel vibrtaes badly..you hit the throttle & let off...almost feels like it is hitting the frame...checked the front motor mount no cracks...but the bottom washer is not snug against the mount ..is that normall on a bike ..
Old Mar 3, 2008 | 07:29 PM
MR. SCOOTINN
Default RE: vibration problem
ttt
Old Mar 3, 2008 | 07:32 PM
bulldogmoe7's Avatar
bulldogmoe7
cant tell you about the washer, but check your belt. mine was a little loose and i tightened it this weekend and went for a small ride and the bike was smooth as ever
Old Mar 3, 2008 | 08:14 PM
hogdoc's Avatar
hogdoc
What year bike? Pre '07 there should be a gap ( about 1/8") between the bracket and the motor mount, if not its collapsed, you wont see a crack! The bottom washer wont sit tight to the mount there is a tube through the middle that the mount and the washer tighten against.
fshaw
EVO
30
Sep 21, 2018 08:14 PM
Ozark Joe
EVO
15
Aug 10, 2018 08:32 PM
Streetrunner
Sep 4, 2013 11:58 AM
jlr1125
Oct 8, 2008 09:22 PM
JnT4Life
Aug 25, 2008 10:17 AM
