Bat Wing Rubber Trim
Old Mar 3, 2008 | 07:52 PM
Rev00's Avatar
Rev00
Default Bat Wing Rubber Trim
Painter removed all the rubber from my fairing so I had to order replacement trim. The best I can remember, there were only 2 pieces. One for each side on the edge. There's not one across the top of the inner that rest against the windshield is there?
Old Mar 3, 2008 | 08:09 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: Bat Wing Rubber Trim
There is a 3-hole piece of sticky sided rubber adhesive that runs across the top of the batwing on the inside of the fairing that rests against the windshield (Part # 58247-96 CUSHION TAPE) and then the TRIM STRIP Part#62786-96 that runs along the skirt at the bottom of the fairing.
Old Mar 3, 2008 | 08:19 PM
Harleypingman's Avatar
Harleypingman
Rev: Are you referring to the inner or outer fairing???
The inner fairing uses two narrow "gaskets" that are easily visible where the outer and inner fairing meet. I replaced them when my inner fairing was painted; I'll see if I still have the part number.
Did your painter remove and save the grommets for the cable and throttle cables?
Old Mar 4, 2008 | 08:50 AM
UltraKla$$ic
Good point. I didn't even think of the inner fairing.
Old Mar 4, 2008 | 06:11 PM
Rev00's Avatar
Rev00
Lets see if the post will go thru this time....
On my inner fairing, I got the two cable grommets and the thin rubber trim that goes on the right and left sides.
On the outer fairing, I have two little rubber tabs on the very bottom.
Nothing on the windshield. I think this is the only trim I'm missing, and I sure don't remember seeing it when I took it apart. (Part # 58247-96 CUSHION TAPE)
Old Mar 4, 2008 | 07:04 PM
stro1965's Avatar
stro1965
My '07doesn't have that cushion tape, never did.
Old Mar 4, 2008 | 07:14 PM
dawg's Avatar
dawg
ORIGINAL: Rev00
UltraKla$$ic is correct
Old Mar 4, 2008 | 07:31 PM
uawman's Avatar
uawman
There isn't any tape by my windshield area but rubber tubing type where the headlight goes.
Old Mar 4, 2008 | 10:33 PM
Harleypingman
My '04 EG has three rubber pieces along the bottom of the outer fairing: one under the headlamp, and two smaller ones on either side of it--I replaced them when the outer fairing was painted.
Motorboatn SOB
May 4, 2017 07:52 PM
KDUBYA
Powdercoat & Paint
Sep 13, 2014 09:03 AM
scot210
Jan 10, 2011 05:20 PM
shore
Dec 10, 2010 07:38 PM
Jukebox
Sep 3, 2010 09:55 PM
