Octane Booster
Old Mar 5, 2008 | 06:24 PM
ROADRAGE98's Avatar
ROADRAGE98
Default Octane Booster
Does anyone know if you can use an octane booster with your bike. Any good or bad results?
Old Mar 5, 2008 | 06:34 PM
shrktooth's Avatar
shrktooth
Default RE: Octane Booster
ORIGINAL: ROADRAGE98
because of your O2 sensors it will leave behind a white residue and harm performance.
i use it in shovels and some evo's - some bikes love it and some it makes no difference on.....but not for O2 sensor bikes
Old Mar 5, 2008 | 06:38 PM
xxxflhrci's Avatar
xxxflhrci
Unless you have bumped up your compression, it is a waste of $$.
Old Mar 5, 2008 | 06:42 PM
cripula's Avatar
cripula
My shovel needs it if I get stuck running less than 94 octane - it was a PITA to have to carry on every trip.
My FLHT has 10.25:1 CR (likely 10:1 in the real world) and runs happily on 91, so no need. More octane isn't always better - do you have a really high comp ratio?
I believe if you aren't pinging you don't need it.
Old Mar 5, 2008 | 06:44 PM
davewear's Avatar
davewear
why do you want to boost your octane rating?
there's some info in this thread that may help you https://www.hdforums.com/m_2911640/tm.htm
Old Mar 6, 2008 | 09:18 AM
captsam54's Avatar
captsam54
Most gas down here in SW.FLA. is rated at 91 octane... BUT is more liike 89... SO.. If you want the best and a good price..
http://www.liquidhorsepower.com/octane-boosters.php
Old Mar 6, 2008 | 10:15 AM
Firetender's Avatar
Firetender
Store-bought "octane booster" is a waste of money, that's a fact. It only raises your octane rating a few "points", which means hundredths of a percent. Real octane booster is straight tech grade toluene or xylene, available at paint, home, or chemical supply houses and is not a ripoff. There are plenty of mixing tables on the internet for using them. They are safe - you are already burning them in your fuel. You can easily carryit in 22 oz. MSR leak-proof fuel bottles in your saddlebag if needed on trips.
Old Mar 6, 2008 | 04:00 PM
nvsteve's Avatar
nvsteve
Ninety per cent or more of us don't need it. In fact less than 91 would work fine if not better for many of us..
If you truly need a boost make your own with toluene and a little MMO.
I had a need for it in a past bike in certain instances and it worked.
All my humble opinion.
Old Mar 6, 2008 | 04:15 PM
DeJavu's Avatar
DeJavu
Ran out of gas at the house and my Evo prefers 93 oct. Had a bottle of booster, filled the tank with my lawn mower gas and gave it a hit of that stuff. Seemed to work OK. Might have been OK with the 89 oct too. Don't know but it was a little insurance.
SmittyFXDL
Apr 23, 2015 11:49 AM
cerelious
Jul 6, 2010 10:49 PM
DyNaBoB
Oct 26, 2009 08:36 PM
JC Rider
Nov 16, 2007 06:15 PM
grippper293
Exhaust System Topics
May 13, 2007 07:08 PM
