V&H true duals
Old Jan 29, 2006 | 11:05 PM
jt cat10's Avatar
jt cat10
6th Gear
Default V&H true duals
i have a 04 flhtci with s.e. air cleaner,V&H ovals and power commander usb3.would installing v&h true duals make a noticeable differance in performance? thanks,greg
Old Jan 30, 2006 | 11:40 AM
CHEYENNE's Avatar
CHEYENNE
Default RE: V&H true duals
Some say you will lose Hp/Tq down low and others claim to have gained. So with that being said.. I don't know
Old Jan 30, 2006 | 12:22 PM
harris48cars's Avatar
harris48cars
I had stock headers and SE slip ons on my RKC but the QUALITY of sound was not very good. As a matter if fact it was very disappointing. I installed the V&H true duals and the improvement was dramatic. Iwasn't looking for loud. And it isn't. just wanted a throatier sound and the duals did that. I'm not a very aggressive rider so I can't comment on the performance side except to say it certainly did not hurt it any.
Gary
Old Jan 30, 2006 | 12:44 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
With a good dyno tune you won't lose anything and the sound quality and look will make you very happy. Don't forget about the improvement with the lack of blistering heat on your right leg from losing your crossover. Your passenger will love you for that.
Old Jan 30, 2006 | 12:45 PM
CHEYENNE's Avatar
CHEYENNE
Hell not having all your sound come from 1 side of the bike when you have duals is what made my decision for me
Old Jan 30, 2006 | 02:19 PM
lil_gmac2's Avatar
lil_gmac2
Can't go wrong with true dual and the bike look much cleaner.
Old Jan 30, 2006 | 06:55 PM
Brucest's Avatar
Brucest
I just put a set of V&H true duals and SE air cleaner on my 1996 Ultra. Runs, looks and SOUNDS much better. This is with a DFO but without a dyno tune.
Old Jan 30, 2006 | 09:12 PM
wnogood's Avatar
wnogood
The biggest gain in my mind was the ability to tune each cylinder individually on the dyno. I am running drag pipes on mine and my hp/tq numbers are right in line with guys running baffled mufflers. The dyno guy was amazed that from the baffled mufflers I started with, then changed to the drag pipes....I actually flattened out my power curve. The baffled mufflers peaked way down low...then fell off as rpm increased. The drag pipes actually peaked a bit higher in rpm but gave a much flatter curve. It's a mod you will never regret.
nogood o~`o
Old Jan 30, 2006 | 10:17 PM
Pauljr's Avatar
Pauljr
I didn't notice any seat of the pants differance but I really like the sound coming equally from both sides.
No more right side pipes blueing. And another positive is opening up the area behind the rear cylinder. Go ahead you won't be dissapointed.
CT-Bagger
Jan 14, 2016 09:54 PM
MrHog
Nov 20, 2015 12:45 PM
Tonebone
Exhaust System Topics
Jul 25, 2015 10:12 AM
Gliden
Mar 18, 2010 11:00 AM
SouthernAlberta
Mar 22, 2009 03:31 PM
