2 Fullsac questions
Old Mar 7, 2008 | 04:02 AM
RangeRat's Avatar
RangeRat
Default 2 Fullsac questions
I've got V&H Ovals on the stock head pipes and want the "true dual" sound. I realize that I shouldn't expect an increase in Tq or HP but that'sOK since all I want is better old-school HD sound.
Is Fullsac the right way to go?
Does anyone have close-up pics of what the resulting right side heat shield gaps look like?
Thx.
Old Mar 7, 2008 | 04:11 AM
pkenyon1's Avatar
pkenyon1
Default RE: 2 Fullsac questions
Not sure what you're meaning....
Did you mean Fuelpac or am I missing out on something?
Changing the mufflers / slip ons doesn't affect the heat sheild gap that you see anyway down by your right foot, before or after that modification it is still there; only changing the header pipes and putting on the different shield will remove that gap. If you want to remove it without replacing header pipes there are after market parts intended just for that purpose.
The noise from my classic slip on V&H mufflers is great, I used the fuel pack and SE airfilter; the bike runs much stronger and no need to go to the expense of changing the headers.
If you want to change header pipes then true duals is the way to go but that is a lot of expense that will have limited benefit without further engine work IMO.
Put on a high performance air filter and buy the fuelpac and you're all set. If you didnt change the filter set up yet then I suggest your bike needs more air going in and management program from Fuel pack to get what you need and ensure correct mixture....changing mufflers only does not help a lot and perhaps this is the next stage you are looking for?
Old Mar 7, 2008 | 04:38 AM
stro1965's Avatar
stro1965
ORIGINAL: pkenyon1
He's talking about the Fulsac true dual conversion kit. I've only ever seen pics of them but the folks that use them seem to like them. I don't think I could get past the heat shield issue but again, maybe in person you really don't notice it too much. I think if it were me I'd spend an extra few bucks and buy V&H headers.
Old Mar 7, 2008 | 04:48 AM
TOMCENTRAL's Avatar
TOMCENTRAL
The V&H true duals can be bought for around $340 shipped.Very nice quality & you can use their FuelPak for management.My 08 Ultra runs superperb w/0vals,TDs,FP,SE a/c.Regards,Tom ps:Sound is awesume!
ORIGINAL: RangeRat
I've got V&H Ovals on the stock head pipes and want the "true dual" sound. I realize that I shouldn't expect an increase in Tq or HP but that's OK since all I want is better old-school HD sound.
Thx.
Old Mar 7, 2008 | 05:57 AM
Mick's Avatar
Mick
Fullsac duals work pretty well and are a nice kit with great instructions.
They're hard to beat for the price.
Here's a pic of them on my bike , you can see the gap for the rear shield and the flipped right side shields.
I suffered a fair torque loss (carbureted) you may not with injection.
The silver pipe looks best with the natural engine , black might look better with black cylinders.
Good value , great sound.
Vance and Hines (and others) look better when installed.
Mick
[IMG]local://upfiles/14587/688FBEC2372C443998A50EC2AFDF05EE.jpg[/IMG]
Old Mar 7, 2008 | 08:40 AM
pkenyon1's Avatar
pkenyon1
Thanks for the info, I never heard of that...
the only Fullsac I have can be emptied at regular intervals .
I still think that if this is a stock intake etc. then that could be the issue regarding sound and therefore power.
Old Mar 7, 2008 | 08:49 AM
FLHT's Avatar
FLHT
I used the kit to covert my stock head pipe and love the kit. You have to some messing with heat shields but in the end its worth it.
Old Mar 7, 2008 | 11:15 AM
RangeRat's Avatar
RangeRat
Yep, already have Stage 1 with PCIII - plenty of power for an old fart and the sound level with the ovals suites me just fine too butwant stereoinstead of mono.
I'm indeed thinking about V&H true duals versus Fullsac mod with an extra $150 or so left over for other stuff. Thanks for the pics guys and yours look pretty darn goodplus wanted to hearaboutreal-world experience with the Fullsac mod. Thanks.
Old Mar 7, 2008 | 06:14 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Do a search for Fulsac Sampson Heat Shield and you will find the part numbers for the heat shields that will not have gaps.
Good Luck
Old Mar 7, 2008 | 09:11 PM
FLHT's Avatar
FLHT
If anybody cares to know I can dig up the part numbers to make your heat shield next to perfect.
