side stand noise play ????????????
Old Mar 9, 2008 | 08:42 PM
relli's Avatar
relli
Default side stand noise play ????????????
just noticed my side stand makes a loud knocking/popping noise when i swing it down. also has a lotta play in the bracket where it pivots like a bushing or bearing is bad or missing??? i dont have anything to compare it to. any ideas??
Old Mar 9, 2008 | 09:05 PM
Bill03E's Avatar
Bill03E
Default RE: side stand noise play ????????????
lube it?
Old Mar 9, 2008 | 09:19 PM
choochoo's Avatar
choochoo
If it is a stock HD jiffy stand.
$60. (or there abouts) is a valuable investment.
Buy the service manual.
It's a simple device, no bearings or bushings.
They sometimes get mud , sand, orpebbles wedged inthem.
Clean it. Does not need lube.
The lube just attracts and traps more dirt and grit.
Old Mar 9, 2008 | 10:12 PM
TexasRedneck's Avatar
TexasRedneck
Sorry - but it DOES need lube, and so states in the service manual. I use a dry graphite lube...
Old Mar 9, 2008 | 10:22 PM
Drifting Texas's Avatar
Drifting Texas
ORIGINAL: relli
That's when I learned to lube mine.
Old Mar 9, 2008 | 10:32 PM
Bill03E's Avatar
Bill03E
I use a teflon dry lube.
Old Mar 9, 2008 | 10:43 PM
sweetglide's Avatar
sweetglide
Dry graphite works great, no more squeakin'
2007 FLHX
SERT
Rinehart TD
SE Air Filter
Old Mar 10, 2008 | 08:49 AM
choochoo's Avatar
choochoo
Yeah but most people when you say "lube" will get out the tub of
bearing grease or the grease gun.
I have never lubed mine and never had a problem with the squeaks etc.
And you all know I live on a gravel road, and that I ride in rain, mud and snow.
Well I can't say NEVER. But I mean never had to lube it.
I just keep it clean, by washing the grime off it.
ORIGINAL: TexasRedneck
Old Mar 10, 2008 | 09:08 AM
uweldit's Avatar
uweldit
I agree with Choo...
I fixed many a kickstand for others that went at it with the grease gun...
I use teflon as I always have some around for my shotshell reloader...
Old Mar 10, 2008 | 11:11 AM
hogdoc's Avatar
hogdoc
ORIGINAL: choochoo
WRONG AGAIN: it does need to be lubed even if you keep it clean it will be metal to metal rubbing everytime you put it up or down. Use a dry graphite or cable lube or even WD-40. Wash it out good when you wash the bike, after you dry it give it a couple small squirts on each side of the stand bracket work it back and forth a couple times to spread it around.
