still, just keeping it clean will normally eliminate the squeaks.
There is really not enough friction or tightness in the parts to
really cause any binding or excessive wear of the parts.
But if you insist a dry lube (teflon) would be the thing to use.
As I said, I rinse mine off when ever Iwash the bike, ride in the rain,
and when the dog decides he needs to relieve himself, or myself for that matter!
And it doesn't squeak!
well upon closer examination the play i see is normal. i used an "aerosol anti-sieze spray" as directed by the manual and all is well. thanks for the help guys.
