Changing front rubber motor mount
Old Mar 10, 2008 | 11:09 AM
yank's Avatar
yank
Default Changing front rubber motor mount
hey guys i am needing to change my front motor mount on my 03 flht. i was looking at it and it looks like i need to remove my regulator and and the bracket to that bolts on to the motor. is there any tricks i need to know before i get started?
Old Mar 10, 2008 | 11:27 AM
run1fsr's Avatar
run1fsr
Default RE: Changing front rubber motor mount
Did the same thing a few months back on my Ultra. Try doing a search for motor mount replacement. Lot's of good threads and info out there.
Old Mar 10, 2008 | 11:28 AM
hogdoc's Avatar
hogdoc
You need a way to hold the bike solid, preferably a table lift. Put a jack with a block of wood under the moter. Remove reg, stabalizer link from frame,andmotor mount center bolt. Raise jack enough to take motor plate off of mount. Loosen plate to motor bolts but leave nuts on. remove mount to frame bolts, lift engine enough to remove mount. Replace w/new mountinstall bolts but leave loose. Lower motor some and tighten plate to motor bolts. As you lower motor, center mount under plate and install center bolt. Lower motor all the way down. Install link bolt to frame and torque all bolts to spec!
Time for a couple beers!
Old Mar 10, 2008 | 11:45 AM
st john's Avatar
st john
Hogdoc, it sounds easy but what about alignment?
Plus would you recommend blue locktite #243 ?
Also is Harley's new style front motor mount in
your opinion ok?
Thanks,
Glen
Old Mar 10, 2008 | 11:50 AM
Beemervet's Avatar
Beemervet
Many feel the new mount is too stiff and reccomend one for a Buell.
Old Mar 10, 2008 | 12:31 PM
run1fsr's Avatar
run1fsr
FYI - I went with theHarley's "new" motor mount and it seems to be fine. Some complain of vibration issues, but no obvious problems here.
Old Mar 10, 2008 | 08:55 PM
hogdoc's Avatar
hogdoc
ORIGINAL: st john
your opinion ok?
Thanks,
Glen
Glen, if the bike is secured on a table and you lift the motor straight up with a flat jack the alighnment should be fine, its still attatched at the top link and the rear mounts.But you could have the dealer check it if your concerned.
We haven't seen any problems with the new mounts, they seen fine, I dont noticeit being "to stiff" on my own bike.
Never a bad idea to use blue loctite on chassis bolts!
Old Mar 10, 2008 | 09:04 PM
cadman311's Avatar
cadman311
The dealer changed mine right after I bought the bike. And I had vibration so much more till it was rode couple 1000's miles.
Old Mar 10, 2008 | 10:04 PM
nujohn's Avatar
nujohn
I changed out my front motor mount with an NEW HdmountWay too hard,too much vibrationat idle So I pick up an after market from JP what a differance
Old Mar 11, 2008 | 05:41 AM
jbhawley's Avatar
jbhawley
I posted a step-by-step how to last summer.
https://www.hdforums.com/m_1710757/tm.htm
