Engine warm up
Old Mar 11, 2008 | 07:45 AM
dog155's Avatar
dog155
Default RE: Engine warm up
The only thing you need to be careful of with a cool motor is reving it.Give it plenty of time to warm up,the cooler the temp the more time it needs.The top end heads etc,warm quickly,the lower end, cylinders and crankcases take longer.
Old Mar 11, 2008 | 07:53 AM
SG 1's Avatar
SG 1
I never like to rev a cold engine. Let it run like the manual says 15-30 secs. or longer. Then take it easy for a few minutes.
blender747's Avatar
blender747
start idle 1 or 2 minutes theneasy riding the next 3-5 miles, then ride it like you stole it
Old Mar 11, 2008 | 08:53 AM
jsimo7's Avatar
jsimo7
I let it warm up 2-3 min while getting gaer on and then ride easy no high revs for 10-15 miles
Old Mar 11, 2008 | 09:04 AM
Secretec's Avatar
Secretec
As long as it takes to get ready. Although after seated on the bike, I hold the clutch in for about 30- 60 seconds and don't rev the engine to put it in 1st. Seems not to have that loud clunk if you do that. A HD guru told me that trick and it works.
Old Mar 11, 2008 | 11:05 AM
Windup08's Avatar
Windup08
I give it about a minute while I'm putting on gloves and stuff, but don't get on it hard until I have several miles on it.
Old Mar 11, 2008 | 11:14 AM
garyhendley's Avatar
garyhendley
well if you have synthetic oil you should be ok with a minute or so
regular oil needs more time to warm up
BASSMAN
Old Mar 11, 2008 | 11:59 AM
IronLegend's Avatar
IronLegend
Like most everyone else's advise givenhere...I push it out of the shed (if at home), light'er up and let it run at idle whilst doning the appropriateriding paraphenalia then away-we-go.
Old Mar 11, 2008 | 12:06 PM
FLHXn's Avatar
FLHXn
I start mine in first gear with the clutch pulled in so I don't have to hear the loud clunk when I put it in first gear.. Then after I back down the driveway, I just ride on.. I usually ride easy for the first mile or two, that's about it. Maybe gets 30 seconds before I take off...
Old Mar 11, 2008 | 12:13 PM
rome304's Avatar
rome304
as long as it takes for the oil light to go off to ensure oil circulation per manual.
