Long term storage suggestions
Old Mar 13, 2008 | 06:02 AM
tvcrane's Avatar
tvcrane
Default Long term storage suggestions
OK I finally have the Harley but I have to deploy for a year plus....
I have a garage and my wife is willing to start it and let it run for about 10 min a month, but is that good?
I've heard of draining the tank.....the local service shops are not much help.
Thanks....
[IMG]local://upfiles/45224/4D3E5783264940CBADA171133931394F.jpg[/IMG]
Old Mar 13, 2008 | 06:12 AM
rocknrod's Avatar
rocknrod
Default RE: Long term storage suggestions
You may want to get a battery tender?
Show her how to unplug it, and plug it in.
Get a cover for it maybe?
Note: If you have kids and one of em plays on it, maybe shifts it in gear?
Moma tries to start it?.... Does she know what to do?
You'll be alright. I used to deploy all the time and leave my street rods.
Moma will take care of things.
Old Mar 13, 2008 | 06:45 AM
DKSS07's Avatar
DKSS07
Welcome to the forum! Thanks for your service. I was told just to fill it up and put it on a battery tender it'll be fine. A bike cover would also be helpful. Come home safe and soon!
Take care.
Old Mar 13, 2008 | 06:58 AM
Windup08's Avatar
Windup08
Good luck with your deployment, come home safe.
Put some stabilizer in the gas and fill the tank up....run it a few minutes to make sure the sabilizer is all the way through the system. You might want to consider fogging the cylinders....spray fogging oil can be found at many boat or wave-runner type shops....just pull each plug and spray a good amount in each cylinder....I do mine while up on a lift, that way I can put the tranny in 5th and turn the cylinders over once or twice, then put the plugs back in. If possible take the weight off the tires, if not possible put a piece of wood under them to keep them up off the concrete. Have it cleaned/waxed good, if mice might be an issue get a good heavy piece of plastic and a soft tie...put one over the end of each muffler. Put a battery tender on it and cover it up. Oh....make sure fluids have been changed. You are probably better off not starting it.
Old Mar 13, 2008 | 07:28 AM
electraride2's Avatar
electraride2
don't cover it... covers hold moisture under them and with different temps and humidity changes you will get a condensation build up under them no matter what....I never cover mine just wash dust off in spring...and yes I would have my wife start it once a month if she runs it til its hot
Old Mar 13, 2008 | 08:29 AM
pkenyon1's Avatar
pkenyon1
HD indoor breathable storage cover shouldn't???!
Old Mar 13, 2008 | 09:45 AM
JakeF14's Avatar
JakeF14
full tank with fuel stabilizer,fog cylenders, batery tender don't start it. standard preservation boats, airplanes, clasic cars
Old Mar 13, 2008 | 09:56 AM
captjon37's Avatar
captjon37
I wonder about the cover with a battery tender and battery gasses being trapped under the cover. I store my boat for that long and i remove the battery and use a tender, fog the cyl, change the eng oil and lower unit oil and wait until summer. My bike gets used all year so others might have mo better bike storage info.
MichaelE
Feb 8, 2010 09:24 PM
Dieselhed
Nov 22, 2009 12:37 PM
PajamaShark
Nov 12, 2009 12:24 PM
ropd0184
Feb 3, 2009 09:43 PM
nkauf21
Aug 22, 2008 09:21 AM
