Guess what, and it's no surprise to me
Because the filter is a Carquest filter made by WIX.
Since the bike has been in the shop (last Tuseday) their story has changed 4 times.
Friday we called to set up an appointment with the Wix filter tech person.
He showed up today.
He says upon looking at the filter there appears to be nothing wrong with it
or the oil pump in the bike or the down stream oil passages (blockages etc).
The filter will go in to the lab and be tested free of charge.
He is going to call the stealer and let them know he has the filter and ask them if they
don't want to change their mind and cover under warranty.
But as it stands now, we will be paying the repairs, and then going to court and prove to
judge the filter did not cause the damage.
The tech also says, the filter can not cause the damage to the tank.
Course you know why we are having to fight the MOCO on this don't you?
I hate to tell most of you this, but you got it all wrong.
MOCO has nothing to do with warranty issues other than giving the dealer their credits for the job.
It's the dealer that is denying the warranty. I'll even go out on a limb here...the dealer fixes the bike, suckers consumer into paying by telling them it's not covered because you used aftermarket part AND files a warranty claim...DOUBLE BENEFITS for the dealer!
Funny, I broke 5 teeth on my clutch basket pinion gear...the dealer never said "it's your 11:1 compression ratio," nor did he say "your Barnett clutch did this." What he DID say when I told him a Barnett clutch was in it, "I don't know anything about it" regarding the clutch and replaced my basket under warranty.
It's NOT MOCO, people!
ChooChoo has not read the Magnusson-Mmorrison act. It implies as a protection to the consumer but states that in the event of failure the manufacture must prove within a reasonable doubt that the failure was caused frominstalled items. If you used the Wix filter and it indeed does not have the bypass valve or a bypass pressure value ratd different than the manufactured part, you will be responsible for repairs. the government states that if a mnufacture claims their parts must be used for warranty to be honored they must supply the parts. If the dealer puts a new filter and fills the oil then has no issues that is enough proof to deny coverage. The only way a dealer can gurantee authorization ofa claim if they are willing to pay themselves.
That would really be the end of all ends, I can hear it now: "No, your engine/transmission electrical and tires are not covered, you failed to use our gas!"
This all sounds like a big racket to me!
choochoo, sorry to hear that all this is going on.
Hope for a speedy resolve.
So yep your first sentence says it all about you.
see my post December 16, 1773 for more info.
And names will be coming when it is appropriate.
I am sorry but I'm kinda lost. On one of the very cheapest maintenance parts on a $10K+ bike you decided to save even a couple more dollars and go even cheaper price wise and now you are having to spends hundreds in non-covered repairs and probably even more in either lawyer fees (or missed time from work if you play lawyer), court filing fees, service fees, and who knows what else, to sue the dealer, with a 50/50 chance at best of winning. Again to save 2-5 bucks? Yeah, makes sense to me.....[sm=confused06.gif]
And I have read it thoroughly.
Also note ; per the WIX TECH REP, Wix makes some of HD's Filters( I can't confirm, only repeat what he said).
ANd the MOCO does have final say!
And my point has been, Dealer Claimed filter was at fault. first it is impossible for the filter
to cause this type of damage (read your service manual). Better yet UNDERSTAND what it says!
And DEALER and MOCO must prove their contention. If they can NOT they must honor the warranty!!!!
Had to edit fingers typed wrong.
TITLE 15 CHAPTER 50 U.S. CODE
