adding mutazu tour pak
Old Mar 17, 2008 | 09:29 AM
dt20's Avatar
dt20
Default adding mutazu tour pak
anybody happen to know what parts I would need to add a mutazu tour pak to a street glide. did a search couldnt find anything on it. not sure what all i would need to make this a detachable set up. any help would be appreciated.
Old Mar 17, 2008 | 10:05 AM
dawg's Avatar
dawg
Default RE: adding mutazu tour pak
The DMY series claims to come with attachment hardware. I am not familiar with them enough to know if it is or can be made an easy detach setup.
Old Mar 17, 2008 | 10:16 AM
masterblaster's Avatar
masterblaster
Suggest that you go to Chicago HD web and do a side by side comparison with the HD king or Chopped TP all in and the Matuza all in. I think I remember it being $200 difference so went with the HD King TP, did not put a rack on it so it looks nice and clean.
Old Mar 17, 2008 | 10:28 AM
lp's Avatar
lp
The Mutazu tour pak is cheap, but works pretty well.
It's only like 110 bucks in vivid black.
The detachable tourpak rack is like 150.00
The detach hardware (goes on the bike) is under a hundred.
The total package? Somewhere around 300-400 bucks.
The HD solution is like 800-1200 bucks.
Later when you want to upgrade to the HD one, the detach hardware and rack can be reused...
research: https://www.hdforums.com/searchpro.a...bmitbutton=+OK
lp
Old Mar 17, 2008 | 11:24 AM
Harleypingman's Avatar
Harleypingman
You buy the same mounting hardware for the Mutazu that you would buy for an HD King or chopped TP: detachable solo or two-up rack, and the appropriate mounting kit to install on the bike to mount the rack. Unlike the HD TP's, the Mutazu comes with a backrest and lock/key. As lp mentioned, the difference in the price of the boxes is about 500 bucks, the backrest will be about 175, plus a lock and key if you buy the HD TP.
I used the Mutazu for about 2 years and it's a great value and easy install on either of the HD detachable racks.
Old Mar 17, 2008 | 11:39 AM
ironhead3fan's Avatar
ironhead3fan
Fugly, but cheap enough. I would use it if I had a Road King or Street Glide, cause I am cheap!!
Old Mar 17, 2008 | 11:43 AM
dirtdobber's Avatar
dirtdobber
I can't help you with the mounting but what ever you do do not install a chrome luggage rack on top. The abs will not take the viberaton. It will crack as where it mounts. The trunks are low cost and will hold up for a good period of time. Several years. The only draw back is the stops on the inside is also abs and will wear through time. You will get your $$$ worth with it though
Old Mar 18, 2008 | 03:34 AM
dt20's Avatar
dt20
thank you all really appreciate it. i think for the price you really cant go wrong with this box. will see!
Doc o
Apr 17, 2011 12:27 PM
Terminator69
Mar 13, 2009 10:31 PM
rizzo
Sep 11, 2008 09:40 PM
adlerx
Mar 27, 2008 02:57 PM
BirchwhiteHD
General Topics/Tech Tips
Jun 8, 2006 07:43 AM
