V&H Fuel Pak and FullSac
DOes any one have a Fuel PaK with Full Sac Exhaust.
I currently have a techlusion DFO, it looks like it needs repaired for the second time in two years. I'll probably switch to something else, and the dealer recommends the Fuel Pak. However, I can't seem to find the right settings for the thing with Full Sac....\
Can anyone help, with a similar set-up?????
RE: V&H Fuel Pak and FullSac
You can either check with V&H for a map buy sending a email. They will respond in less than 48 hours except weekends/holidays or you can call. Be prepared to be put on hold for a little while. Or you can check with http://www.fullsac.com/ for a map.
ORIGINAL: websterdan
Just curious what was the problem with the DFO I have had one for 3 years and no problems so whats up??? Knock on wood!!
The first time it went bad was a broken wire, now it started out throwing an engine check light, and the more I ride the worse the miss and the way the bike runs. I'm going to dicconnect and drive for a few days to make sure it is the DFO. If it isn't I WILL be sure to let everyone know, I was mistaken.
My bike is 2 years old with just 22,000 miles on it. I don't get to ride as much this last year.
