Fuel Pak Maps
Old Aug 22, 2012 | 05:08 PM
olemiss8's Avatar
olemiss8
Default Fuel Pak Maps
I'm putting se 255's cams on 08 street glide, I was looking for someone that has this setup and what map you used. Called tech support at FP and they dont have specified map for this cam. thanks
Old Aug 22, 2012 | 05:25 PM
BackRoader's Avatar
BackRoader
They did not have one for my setup either. Go to their website and find the map lookup area, enter your values for your setup, when u come to a entry that has no listing for your setup, choose "other" and it will give u the option to e-mail them with your set up info. They will create or reccomend a map for u, or at least they did for me. They have good customer service and will respond to your email pretty quick.
Old Aug 22, 2012 | 05:37 PM
Shredding rubber's Avatar
Shredding rubber
I had a fuel pak before I bought a pc-v. It's an utter pos. Buy a real tuner. You aren't going to be happy with it's performance.
Think about it. All a fuel pak does is adjust fuel. Like changing jet sizes. In a carb'd bike when you swap cams a timing adjustment is also necessary which just isnt possible with a fuel pak.
I was so dissatisfied with the fuel pak I threw it in the garbage. I refused to sell it to someone. I felt like I was scamming them.
Old Aug 23, 2012 | 04:49 PM
olemiss8's Avatar
olemiss8
Update on se 255's install.....with fuel pak
I used fuel pak map #1880
se 255's cam
It has really strong accel all the way thru the gears. No popping on decel. It pulled real strong up hills in 6th gear. It is 96 degrees today and start and stop riding no pinging. as of right now very happy with the install.
Old Aug 23, 2012 | 05:14 PM
BackRoader's Avatar
BackRoader
Some do not like the FuelPak. I have had good results with mine. Enjoy!
ggrif
Exhaust System Topics
16
Dec 29, 2009 05:10 PM
rm4040
Aug 31, 2009 10:24 AM
dontdropit
Apr 25, 2009 08:26 PM
harleyflo
Jul 30, 2007 10:15 PM
makoshark333
Apr 25, 2007 01:25 AM
