starter removal 2004 road king
Old Mar 17, 2008 | 09:24 PM
royal1's Avatar
royal1
Stage I
Default starter removal 2004 road king
Can anyone please tell me how to remove the starter from a 2004 Road King?
Old Mar 17, 2008 | 09:26 PM
bubbabear's Avatar
bubbabear
Default RE: starter removal 2004 road king
Go buy a shop manual, that's easiest thing to tell you. It's worth the money.
Old Mar 17, 2008 | 09:28 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Having the SERVICE MANUAL would be the way to start. Think it's one of the first Add-On HD owners make...
Old Mar 17, 2008 | 09:32 PM
skltr's Avatar
skltr
+1
Old Mar 17, 2008 | 09:34 PM
sumdumtech's Avatar
sumdumtech
REMOVAL
1. Remove seat. See Section 2.24 SEAT, REMOVAL.
7[size=4]8
WARNING
To protect against shock and accidental start-up of vehicle,
disconnect the negative battery cable before proceeding.
Inadequate safety precautions could result in
death or serious injury.
2. Unthread bolt and remove battery negative cable (black)
from battery negative (-) terminal.
3. Remove the primary chaincase cover. See Section 6.5
PRIMARY CHAINCASE, REMOVAL, steps 3-8.
4. Bend tab on lockplate away from head of jackshaft bolt.
5. Holding pinion gear to prevent rotation, remove the jackshaft
bolt with lockplate and thrust washer.
6. From right side of motorcycle, remove starter front
mounting screw with lockwasher. Remove rear mounting
screw with lockwasher (and battery negative cable ring
terminal). Remove Keps nut from stud of bracket tab and
remove exhaust support bracket.
7. Pull back rubber boot and remove flange nut from starter
post. Remove main power and battery positive cable
ring terminals from starter post. See Figure 5-3.
8. Depress external latch and pull solenoid connector from
top of starter housing.
9. Locate oil filler plug/dipstick on right side of motorcycle
at top of transmission case. To remove the oil filler plug,
pull steadily while moving plug back and forth.
10. Remove the starter from the right side of the motorcycle,
carefully sliding it through the space between the
exhaust pipe and side cover
If your just removing the starter start from step 6
[IMG]local://upfiles/55106/C2B3C80955AE43FE9763A3EAC629C1BC.jpg[/IMG]
Old Mar 14, 2019 | 04:34 PM
04ctd's Avatar
04ctd
bumping a 10 year old thread because it looks like you no longer need to remove the primary, but i had to GOOGLE a ton of stuff to verify, this is from the other forum:
"the need to remove the primary was gone when the 6 spd arrived in 06 dyna's and 07 up bikes, remove the battery cables, unplug the solenoid wire and remove the two bolts and depending on exhaust you may have some brackets on the front or both bolts, simply pull the starter out after that. Good idea to replace the o-ring on the starter nose upon re-Assembly"
Old Mar 14, 2019 | 08:23 PM
ORradtech's Avatar
ORradtech
Doesn't really change how to do it on an 04 RK...
Best advice, even 10 years later, is to buy that service manual. No Google necessary then.
2002SilverSurfer
Electrical/Lighting/Alarm
Apr 27, 2012 10:02 AM
loumack
Engine Mechanical Topics
Dec 4, 2010 11:07 PM
1wldtrky
Jul 7, 2010 02:41 AM
1wldtrky
Jul 5, 2010 05:53 PM
1wldtrky
Jul 5, 2010 05:40 PM
