Batteries
Old Mar 28, 2008 | 08:57 PM
maineultraclassic's Avatar
maineultraclassic
Default RE: Batteries
ORIGINAL: Whiskyb
Thanks for all the replies, I ordered my Odessy yesterday, should be here end of next week. Go figure that it is supposed to be above freezing here beginning of next week. Incidentally for the flht they recommend their metal wrapped battery. Apparently it is better dealing with any heat issues. Heres hoping
What model did you get?
Where did you buy from, and how much?
I've been looking at this one - http://www.odysseybatteries.com/battery/pc925lmj.htm
Steve
Old Mar 28, 2008 | 09:07 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
ORIGINAL: Cryptoboy
...might just stick with a stock HD battery again!
+1
Still running on my stock battery 3.5 years old (no battery tender) and approx. 46k miles.
Dave
Old Mar 28, 2008 | 09:11 PM
2008FLHP's Avatar
2008FLHP
ORIGINAL: EastSideBikerTrash
ORIGINAL: Cryptoboy
+1
Dave
i think i have the original battery on a 5yr old bike and checked it yesterday, 12+V
Old Mar 28, 2008 | 09:39 PM
smitty901's Avatar
smitty901
I would be looking at what else maybe wrong My HD battiers last 4 to 5 years and work fine.
No madder who'sname is onthem there are top shelf battiers those in the middle and walmart.
My FB is a carb model and it is a hard starter on 30 degree days... it is a 96 and is just on the third battery first two lasted just over 5 years each.
I do use a battery tender NOT a charger if the bikes sits for more than a couple weeks.
Over charging a battery will kill it.
There is a difference between a good brand tender and a cheap charger.
Old Mar 28, 2008 | 09:59 PM
Taterdog's Avatar
Taterdog
For those who use them, what model Odyssey battery fits our touring bikes?
Old Mar 29, 2008 | 06:49 AM
Whiskyb's Avatar
Whiskyb
Heres the link to their application chart http://www.odysseyfactory.com/docume...G-002_0905.pdf The mj stands for metal jacket and it is only recommended for a few. Suppose to deal with heat better. For those who said about using a factory battery this is cheaper.
Old Mar 29, 2008 | 07:32 AM
maineultraclassic
ORIGINAL: Whiskyb
So I'm going to assume that you did go with this one - http://www.odysseybatteries.com/battery/pc925lmj.htm ?
And you said you found it cheaper then the factory battery, where?
Steve
Old Mar 29, 2008 | 07:54 AM
DBLRRCN's Avatar
DBLRRCN
Odessey Only way to go. The service is the best. I have one in every thing I own and Run them in the Spec sprint car and not had a any probs. there the best. Sealed ( No Leaky acid)..
Old Mar 29, 2008 | 07:56 AM
Roadjunkie1's Avatar
Roadjunkie1
This is one situation where you can't go wrong with an OEM battery. HAve one on my RG..5 years old. Use a trickle charger year round. Going to replace it only because it's 5 years old.
The trick to battery longevity is a trickle charger, especially on a bike equipped with an alarm system.
BTW, have put 40,000 miles on this battery. It's not the age, it's the duty cycles. Have heard of batterys in low milage bikes (on a trickle charger) lasting 7 plus years.
Unless you have very high compression, such as that of a 103ci, stick with stock.
"Don't fix something that don't need fixin"
Out of curiosity, what is the cost of the Oddessy?
Old Mar 29, 2008 | 08:04 AM
Whiskyb's Avatar
Whiskyb
Oddesy here in Canada at Total battery in barrie is 120, Stealer wants 135. Local auto parts place quoted 140 for a lead/acid. If the moco has changed suppliers in the last few years what makes you guys think that the new supplier will be as good as your battery from 5 years ago.I could follow your point better if you actually said the Exide or Yuasa.
