DTT Install Help
So what I have put together here is a list of some of the technical things that you have to do that Harley doesn't want you to know about.
First is the location of the idle adjustment set screw. This is required to know where to adjust the IAC
Next is the location of the Throttle Position Sensor or the TPS
One of the brass bushings removed
Removing the other one
Re-Installed TPS with required washers
After setting and dialing in TPS
And lastly 3 very important items you must have
Not sure if you were doing it that way or not.
Steve
Steve
