Solving Spark Knock
Old Mar 24, 2008 | 01:52 PM
russl179's Avatar
russl179
Default Solving Spark Knock
I am getting spark knock in 5th and 6th gears (sounds like loose change in the front cylinder). I am using Chevron/Texaco 93 octane. What can I do about this?
Old Mar 24, 2008 | 02:13 PM
hotpursuit's Avatar
hotpursuit
Default RE: Solving Spark Knock
add more fuel... flash, tuner anything will help... stock they are just too lean
Old Mar 24, 2008 | 02:16 PM
FLHT's Avatar
FLHT
If you are riding a 2007. I'm pretty sure I read where there is a free download for this from your dealer.
Old Mar 24, 2008 | 02:19 PM
Norm's Avatar
Norm
How long has this been doing this? Did it start after refueling? Any mods? Need a little more info.
Old Mar 24, 2008 | 02:27 PM
russl179's Avatar
russl179
ORIGINAL: Norm
Stock everything. It started about two months ago. Dealership told me that I should stop using any type of gas treatment. The knocking happens when I accelerate quickly on the interstate....5 and 6th gear....
Old Mar 24, 2008 | 02:35 PM
hotpursuit's Avatar
hotpursuit
too much load on engine in top gears at too low of rpm will cause it but if you give it more fuel through a tuner/ fuel management you can get rid of it..
Old Mar 24, 2008 | 03:01 PM
Norm's Avatar
Norm
+1 with what hotpursuit said. No check engine lights, no codes. I don't really thing your additive will hurt but, I don't think it will really help either. I'd also try a different brand fuel just to see if there is an improvement. I'm sure you just didn't start lugging in the last two months. Don't the 07's have a knock sensor?
Old Mar 24, 2008 | 03:15 PM
twincam47's Avatar
twincam47
Have you changed plugs or wires that are not H-D? Could affect "ion sense". Search if the search is up for an explanation.
Also the calibration that you might want to look at...
the last bulletin was issued 2-7-08 and was M-1186A (product program 0903) regarding calibration upgrades for 2007 big twins...this should be free but you would need to talk to your dealer to see what you currently have.
good luck
Old Mar 24, 2008 | 03:21 PM
Firetender's Avatar
Firetender
A safe short-term solution to engines with knock sensors is using 10, 20, or up to 30% toluene or xylene (chemical or paint supply stores, about $ 3.50 / gallon) to increase the octane rating and raise the knock threshold. Engines with knock sensors retard the retard the spark timing (robbing you of power) at the onset of knock. This higher threshold will allow combustion and charge expansion to occur so that more force is put into the power stroke. However, higher octane fuel only helps you make more powerat the verge of detonation, so a tuning device is still the most cost-effective long-term solution. Cooler thighs too!
Old Mar 24, 2008 | 03:22 PM
russl179's Avatar
russl179
I just checked with HD. There has indeed been an issue with spark knock in many 2007's. They have issued a FREE download to resolve this problem. If any one needs it, it is on HD's Digitial Tech 2, part number 32903-07E. Mine will be installed tomorrow morning. Thanks!!!
