Warped Rotors
Old Mar 24, 2008 | 08:05 PM
TennRider's Avatar
TennRider
Default Warped Rotors
Since buying my 96 Ultra, I've noticed that my front rotors are warped and need replacing.
Now my question is... How hard is it to remove the front wheel andreplace front rotors ?
I am mechanically inclined and quite capible of replacing rotors on a cage, but if you screw up on a bike.... well we all know what would happen.
Is this something that is fairly easy to do or should I spend the hundred dollars or so on labor and get my mechanic to do the job ?
Old Mar 24, 2008 | 08:07 PM
eglidetrike1's Avatar
eglidetrike1
Default RE: Warped Rotors
Buy yourself a service manual, it is a fairly easy job to do.
Old Mar 24, 2008 | 08:18 PM
maineultraclassic's Avatar
maineultraclassic
Very very easy job to do...............but I highly recommend getting the service manual for your bike so you'll have the proper torque specs for putting it back together.
Steve
Old Mar 24, 2008 | 08:23 PM
skltr's Avatar
skltr
+1, the best $50 you can spend
Chicago Spike's Avatar
Chicago Spike
Plus, think about upgrading your rotors to a full floating rotor too. Go to this board, ask Howard at Motorcycle Metal for some floating rotors and he'll set you up;
https://www.hdforums.com/forumid_315/tt.htm
Old Mar 24, 2008 | 09:26 PM
TennRider's Avatar
TennRider
I appreciate the vote of confidence.
I do have a service manual and will look into it a little closer.
Next question...
What is the advantage of a floating rotor ?
Old Mar 24, 2008 | 09:33 PM
Beemervet's Avatar
Beemervet
ORIGINAL: TennRider
Now my question is... How hard is it to remove the front wheel and replace front rotors ?
The first question should be why are your rotors warped? I'd hate to have to replace them a second time...............
Old Mar 24, 2008 | 09:37 PM
anubisss's Avatar
anubisss
You can do it no problem if you can do a car. Get the manual too.
Old Mar 24, 2008 | 09:42 PM
Chicago Spike
Flaoting rotor advantage is they can heat up and expand without warping. They can disapate heat better and don't fade as solid rotors can. Also, no pulsing through to your fingers
Old Mar 24, 2008 | 09:45 PM
ratcat's Avatar
ratcat
Hey Tennrider, If ya cook your brakes, especialy harley brakes, you gonna warp your rotors. By "Cook" I mean over heat them to the piont they destort or warp. I found out early on with my fatboy, you can't ride it like a race bike, meaning, full throttle... then full brake, corner, repeat.
