neck zert
Old Mar 26, 2008 | 10:30 PM
cirhere2's Avatar
cirhere2
Default neck zert
How much grease to putin?
what kind is best?
And how do you get to the $^%$$#) thing
Russ
Old Mar 26, 2008 | 10:59 PM
Paniolo's Avatar
Paniolo
Default RE: neck zert
The easiest thing to do is take a small wrench and remove the factory one and replace it with a 90 degree elbow fitting. Then angle it toward you. Then using any type of good automotive grease, (spend the extra buck or two at PepBoys) start pumping it in. When you see it spilling out around the neck area, you are done.
Don't be surprised at how much grease it takes.
Old Mar 26, 2008 | 11:30 PM
Northside's Avatar
Northside
ORIGINAL: cirhere2
what kind is best?
Russ
Replace the straight zerk with a 45 or 90 degree to more easily get your grease gun on it. I like the 45 better. My '07 Street Glide took about 1/2 of a tube before the bearings were oozing new grease. Funny but when it was new the fork lock didn't engage when I locked the ignition. I told the Service Manager that I was going to bring it back. After I greased the steering head at the 1000 mi. service, the fork lock started working just fine! I read some posts here a while back saying some guys don't think it's worth doing (greasing the steering bearings), and complained the grease comes out in hot weather and caused a little mess. I'llthink they'll regret it later, but I just ain't smart enough to understand why it's better to let your steering bearings go dry.
Old Mar 26, 2008 | 11:52 PM
mvinc01's Avatar
mvinc01
Been looking for mine on my '07 Road Glide. I can see my buddys on his Ultra plain as day, but can't seem to find the one on my bike. Anyone with a RG that can point me in the right spot?
Old Mar 27, 2008 | 12:10 AM
vibr8ir's Avatar
vibr8ir
I had to remove a plug and install the fitting.. the plug is on the left side
of the frame neck,down by the lower bearings,it takes 1/2 tube too
Old Mar 27, 2008 | 02:57 AM
WildBill2566's Avatar
WildBill2566
I kept the stoch grease nipple, but bought a 90 degree baynet adapter for my grease gun. I find it easier to use. The link below should take you to an image. Cost about $8 and if you Google GREASE GUN ADAPTER it will show some options.
http://us.st11.yimg.com/us.st.yimg.c...1995_224853220
Old Mar 27, 2008 | 06:25 AM
dawg's Avatar
dawg
ORIGINAL: mvinc01
It's in the same exact spot......just a lil harder to see
Old Mar 27, 2008 | 06:42 AM
rocknrod's Avatar
rocknrod
ORIGINAL: WildBill2566
http://us.st11.yimg.com/us.st.yimg.com/I/sjdiscounttools_1995_224853220
Where did you find that?
Oh, I found it:
http://www.sjdiscounttools.com/the418.html
Also, I see there are 65 degree fittings at McMaster-Carr.
Old Mar 27, 2008 | 07:00 AM
captjon37's Avatar
captjon37
Is filling it up really necessary? I wonder because the steering does not turn that much. Is that the only way to get the grease to the bearings? meaning fill it so it will reach it. I have heard a few complain about the mess with the heat. Just wondering.
Old Mar 27, 2008 | 07:29 AM
n.o.yat's Avatar
n.o.yat
do i have one on my 08 s/g and if i do where do i find it/
