Roadking misfiring problems
Old Mar 29, 2008 | 01:15 PM
BrokenRK's Avatar
BrokenRK
6th Gear
Default Roadking misfiring problems
1999 Roadking misfiring on back cylinder 4 times to the front one misfiring 1 time. Anyone have a clue?
Old Mar 29, 2008 | 01:36 PM
Beemervet's Avatar
Beemervet
Default RE: Roadking misfiring problems
Check for cracked Y pipe at rear cylinder. Check for loose pipes. Is it misfire or decel popping? Check intake gaskets.
Old Mar 29, 2008 | 09:29 PM
BrokenRK's Avatar
BrokenRK
6th Gear
That has been checked. Has Rinehart true duals. It started it about 3 weeks ago. If you look at the throttle body it has two ports. You can see the sparks in there.
Old Mar 29, 2008 | 09:54 PM
03dragonRK's Avatar
03dragonRK
Have you had your fuel filter changed in the last month? It is possable that you have a leak inside the tank. The plastic hose from the pump to the filter have also been known to spring a leak. When this happens the fuel pressure to the injectors drops to low and the bike will back fire through the T-body. I just fixed that issue today with my 03. I tested the pressure leaving the tank and it was at 30 psi running and after fixing the problem it was at 56 psi and runnig good.
Old Mar 30, 2008 | 05:12 PM
BrokenRK's Avatar
BrokenRK
6th Gear
I will check that out too. Thanks
GearHeadedWeerdo
Sep 18, 2015 10:39 PM
hockeynutz69
Engine Mechanical Topics
Apr 3, 2014 11:27 AM
birdmandave
Jul 5, 2012 05:43 PM
Navyrep1
Jul 11, 2011 02:27 PM
quadhauler
Mar 13, 2007 12:04 AM
