Hydralic Floor Jack for Glides
Old Apr 2, 2008 | 12:23 PM
  #41
flyingace's Avatar
flyingace
Default RE: Hydralic Floor Jack for Glides
ORIGINAL: FLHT
I have one question for you guys that go out and spend big bucks on a jack for your bike. Did you do the same for your car or your truck? I know my car came with probably a $20.00 scissor jack, if that. I have never considered changing it.
Ill answer your question with another question. If your TRUCK falls off that $20 jack, does it land on its wheels, or does it fall on its side causing hundreds if not thousands of dollars of damage?
Wanna buy/use a cheap bike jack? Its your bike, your money, and your choice. I choose not to.
Old Apr 2, 2008 | 12:32 PM
  #42
flyingace's Avatar
flyingace
ORIGINAL: electaRICK
now hes grabbin at straws???
I gotta arm out for ya!!!
Old Apr 2, 2008 | 12:41 PM
  #43
FLHT's Avatar
FLHT
ORIGINAL: ww1flyingace
ORIGINAL: FLHT
Not if you have the wheels off. Like I said I have never felt my bike was in danger of falling off. If I ever did feel like it was you can bet I would have a different jack.
Old Apr 2, 2008 | 12:44 PM
  #44
FX4's Avatar
FX4
Okay let me try one more time: Will the J&S Jack take a smaller bike or is it pretty much designed for a Harley frame?
Old Apr 2, 2008 | 12:58 PM
  #45
Badfinger's Avatar
Badfinger
Jim,
I have owed the Sears red jack, my buddy owned a Pep Boyz version (until it damn near dumped his dyna on its side) and I now own a J&S. Here are the major differences:
1. The lift arms on the J&S are spaced further apart than the cheaper jacks. This is the source of the greater stability. My sears red jack was a big pain in the *** to try and get the jack under the bike at the correct "balance point". If it was not in just the right place under the bike (front to back) the bike would tip towards the front or back. And of course, the "balance point" seemed to be right where the jack would interfere with my jiffy stand.
2. The lift arms on the J&S are LONGER than the cheaper jacks. My sears jack only had about 1/2" of arm protruding past the bikes frame rails on either side. Adding one more thing to have to be that much more careful about when positioning the jack. Also, if your that close to the edge of the jack, and someone should manage to give the bike a good bump while on the jack....its going off.
3. The "security bars" on the sears jack I had, as well as my buddys pepboyz jack, were a joke. The construction consists of 4 pieces of 3/8" round bar welded to the lower rail of the jack, which a pointed arm is supposed to engage to secure the jack. Cheesy construction aside the fact that the "hook" engaged only on ONE side of the jack, due to the security arm being about as strait as a dogs hind leg did not give me any confidence. On the J&S, BOTH sides fully engage securely into a cutout in the bottom rail of the jack.
4. I had to drive my EG Classic onto blocks in order to get the sears jack under the bike, It would not slide under otherwise. The J&S will fit under my Streetglide with no problems, and it is (of course) lowered in the back compared to the Classic.
5. The J&S is simply built better. The sears jack looks like it was made in china, by the third shift, on a friday.
When I had the sears jack, the only way I felt safe with my bike on it, was when I left one of the bikes wheels on the ground. And even then, I never felt good about it.
I have almost 28K wrapped up in my bike. Im not going to risk finding it laying on its side in my garage because I tried to save $300 on a jack.
God bless ya Brother that's the kind of answerI was looking for. Something substantive and not just more cheer-leading
Ride well,
Jim
Old Apr 2, 2008 | 07:32 PM
  #46
flyingace's Avatar
flyingace
Your welcome.
A bit additional.
According to a review I just found, the Sears Red jack has lifting pads that are 13" long, and 8.5 inches apart.
I just measured my J&S, the arms are 16.25" long, and are 13.5 inches apart. (a full 5 inches wider span) Basically, if you put the rear lift pad in the crossover piece at the back of the frame, the front pad will be as far forward as it can go, before the frame starts to curve upward.
Old Apr 3, 2008 | 03:21 AM
  #47
Capt Jim's Avatar
Capt Jim
What's the difference between the sears yellow jack and red jack, besides color??
Old Apr 3, 2008 | 08:21 AM
  #48
flyingace's Avatar
flyingace
ORIGINAL: Capt Jim
I don't have any personal experience with the yellow jack, so I don't know about lift pad length, span or build quality. Two major differences I do know of, are that the yellow one is aluminum (lighter) and has a lower minimum height by about 3/4 to 1".
Old Apr 4, 2008 | 12:13 PM
  #49
racklefratz's Avatar
racklefratz
ORIGINAL: Badfinger
I'm merely performing due diligences before making another purchase and trying to use this forum for information as intended.... I can't find ant specs on Assembly, materials, etc.
Apparently, your "due diligence" didn't include reading this page, which has all of the above - specs, assembly, and materials.
Old Apr 4, 2008 | 12:37 PM
  #50
empireking13's Avatar
empireking13
does anyone know will the j&s jack lift a electra glide thats been lowered 2 inches?
