leaky oil lines,1991 FLHS
Old Mar 31, 2008 | 11:19 AM
guitbike's Avatar
guitbike
6th Gear
Default leaky oil lines,1991 FLHS
i was inspecting my bike and i saw some oil at the bottom of the frame,upon further investigation i found out that it was coming from the oil lines that had rubbed on the frame around the swingarm area,i took everything out and found out that the brake oil line coming from the reservoir going to the master was just about ready to give up too,there was also some electrical wires shields that also needed attention,i replaced everything with brand new dealer parts,i put some flexible electrical wire conduit around the oil lines at places where they touched the frame,fixed the electrical wires too,everything should be good for another 20 years,i just wanted to share my experience with other people,if you got an older machine make sure you inspect those out of sight area,it can be pretty nasty if you would end up on the road with brake fluid or engine oil spraying your back wheel.
peace.
despurlock
Aug 30, 2013 02:49 PM
shizzomynizzo
Ironhead
Jul 14, 2010 12:12 PM
04fxdwgi
Jan 1, 2009 02:09 PM
polar121
Flathead
Apr 2, 2007 09:59 PM
WARG
Jul 31, 2006 03:11 PM
