What To Do?
Old Mar 31, 2008 | 05:05 PM
scofield333's Avatar
scofield333
Default What To Do?
Just got back from a trip to Charleston, SC from the Altanta, GA area on my new 08 Ultra, it had about 700 mile on it when I left and I did 538 in the rain and the cold. Anyway after a long run of around 120 mile or so when I pulled of to take a break I noticed my Idle was acting strange, anywhere fro 10K to 2)k and everywhere in between and the gas MPG going down there sucked really bad -anywhere from 30 MPG to 37 MPG. I was riding 2 up with gear but I would expect more than 32 MPG. Coming home it got alot better both tanks I check where right at 41+ MPG which I was glad to get, I was 2 up coming back also same everything. ANyone have any info on the Idle and the thing sucking gas? I have a stage 1 with slip on V & H and that's it. Thanks for any info before I head off in searh of something the stealer will say.
[IMG]local://upfiles/33788/3EE1F26DFD2F46AF9C0F8CE02ECEEAD3.jpg[/IMG]
Old Mar 31, 2008 | 05:12 PM
2008FLHP's Avatar
2008FLHP
Default RE: What To Do?
do you have any fuel management system on it?
Old Mar 31, 2008 | 06:06 PM
scofield333
[quote]ORIGINAL: 2003FLHPI
No I do not , was thinking of a FUELPAK or SERT
Old Mar 31, 2008 | 06:21 PM
Big Pig's Avatar
Big Pig
Thats probably why then. As I was told with the FI '08's when you add the slip on and Stage 1 kit then you need at min the Stage 1 download and even better yet a FMS or tuner. Even though it has o2 sensors still the addition/changing of the pipes and the air kit throws the air fuel mix outta sync/wack withoutthe DL, FMS or tuner.
Old Mar 31, 2008 | 06:23 PM
oldhippie's Avatar
oldhippie
ORIGINAL: scofield333
Try this thread. https://www.hdforums.com/m_3108859/tm.htmIt might be of interest regarding TBW on 08s.
Somethign to think about, is when you start a post be specific in the Subject so that others know what the topic is if they are searching for answers. "What To Do" could be about anything, including your girlfirend.
Old Mar 31, 2008 | 06:27 PM
maineultraclassic's Avatar
maineultraclassic
There has been a lot of talk online about the new TBW system sticking, and has been reported to have caused a few accidents also.
Steve
Old Mar 31, 2008 | 07:02 PM
DADAWG's Avatar
DADAWG
all the trouble was with the 1 tank of gas and the other tanks ran fine . it could be as simple as a bad batch of gas in the 1st tank.
Old Mar 31, 2008 | 07:16 PM
jujuPOPE's Avatar
jujuPOPE
INSTALL A TUNER
Old Mar 31, 2008 | 08:27 PM
HDQuest's Avatar
HDQuest
Recently rented anew 2008 EG Standard, w/20 miles on the odometer, and encountered same idle problem. I called the dealer and and I was informed on the 2008 this is typical for the first 1000 miles. After about 30mins fo riding the idle was normal and did not reencounter the prblem.
WarBootie
11
Mar 29, 2020 09:13 AM
CodeRed
Oct 5, 2014 06:20 PM
ballbreaker69
Jun 1, 2010 03:37 PM
08FXDC
Exhaust System Topics
May 18, 2009 10:18 PM
itsmyforte
Jan 29, 2008 08:47 PM
