Need help changing windshield
Old Feb 8, 2006 | 11:46 PM
nardo's Avatar
nardo
Default Need help changing windshield
Have a 4" windshield to replace the large windshield on my 2003 E Glide Classic. Loosened the 3 screws on outside of the fairing. Instructions say to loosen 2 screws on inside, but I don't see any. It seems to be loosening up when I work it back and forth a bit. My question is: Should I keep working it loose or are there 2 more screws that need to be loosened some where on the inside? Thought I had better ask before I break something.
Old Feb 8, 2006 | 11:50 PM
MACK's Avatar
MACK
Default RE: Need help changing windshield
the 3 screws are all that it takes. just take them all the way out and you can lift the windschield out.
Old Feb 8, 2006 | 11:51 PM
roadglide65's Avatar
roadglide65
Make sure you take the center one out and it should come off, The 2 screws on the inside are torx and they should be under the speekers.
Old Feb 9, 2006 | 12:14 AM
classic cruiser's Avatar
classic cruiser
You should loosen the two screws inside the fairing along with the three on the front. I think they are below the speakers if I remember right. It will make the job a lot easier.
Old Feb 9, 2006 | 12:45 AM
mikeisglidn's Avatar
mikeisglidn
ive never had to loosen the inner faring screws just the 3 on top and the ws pulls right out
Old Feb 9, 2006 | 01:44 AM
Tom's Avatar
Tom
6th Gear
Mike is right -- all that is normaly needed is to loosen the 3 screws, the windshield is notched and should pull straight up. You may need to rock it side to side due to a small amount of rubber selant that the factory put on it to reduce rattle noise. By loosing the faring screws on top would also alow you to widen the gap, but I have never had to go there.
Old Feb 9, 2006 | 08:50 AM
DI75's Avatar
DI75
3 screws only. Done deal[8D]
Old Feb 9, 2006 | 11:52 AM
Wally's Avatar
Wally
Carfeul when you retighten them. You don't want to strip the brass nut out of the plastic they are molded into.
Old Feb 9, 2006 | 12:02 PM
daboys53119's Avatar
daboys53119
I changed my stock windshield out for a fastaire on my 2000 Ultra. The stocker was in since new as far as I could tell and it did present some resistance. Rock back and forth gently and it should pull straight up.
Old Feb 9, 2006 | 09:31 PM
nardo's Avatar
nardo
Thanks for all the help fellas. Valuable information can be had here. Got home from work today and went at it. With just a little wiggling it came out. Popped in the new tinted 4", stepped back and soaked in the new look. YES! Just what I was looking for.
leftyjm
2014-2024 Touring Models
Aug 17, 2016 06:22 PM
oakmossy
Nov 22, 2014 10:27 AM
t059736
Dec 16, 2010 03:53 PM
trigger1911
Jun 24, 2009 07:51 PM
IamZardoz
Jan 5, 2008 09:13 AM
