Green Fluid
Old Apr 6, 2008 | 07:41 PM
Beemervet's Avatar
Beemervet
Default RE: Green Fluid
V-Rod leaking antifreeze?
Old Apr 6, 2008 | 07:59 PM
asuperheat's Avatar
asuperheat
Good catch dawg did not look at the sig. Maybe he had it lowerd?
ORIGINAL: dawg
Doubt it's Belray being it's an 08 unless he had an Indy do something for him.
Old Apr 6, 2008 | 08:29 PM
torq's Avatar
torq
i second the steering head bearing grease i have cleaned up the excess multiple times and it still runs all over
Old Apr 6, 2008 | 09:29 PM
pop1's Avatar
pop1
thanks for the responses guys. I never had it lowered and it is an 08 with all stock fluids. it seems to be leaking from the very bottom of the fairing and running down the left fork. I see alot of bearing grease but this is oil............. like splashes on the tank it looks like possibly the top of the fork.
Old Apr 6, 2008 | 09:55 PM
skltr's Avatar
skltr
ORIGINAL: glide
Steering head bearing grease, if you look under the lower bearing, you'll see where it's running out from.
+1, the HD stuffbecomes fluidpretty quickly
Old Apr 6, 2008 | 10:04 PM
Pelonz's Avatar
Pelonz
Does it really matter ? Let the dealer figure it out and fix it under warranty. You cant tell them what to fix.
Old Apr 6, 2008 | 10:45 PM
Dirty Dan's Avatar
Dirty Dan
its washer fluid, got it filled too high, dont forget to check the wiper blade too
Old Apr 6, 2008 | 11:15 PM
ratcat's Avatar
ratcat
I had this problem too.
Back in the early 80's I'd race around on my Z-1 900 kawy and when the law was on my tail, I'd hide my beverage up in the fairing, but as I'm getting out my lic. and reg. to show the MAN, I would hear my beverage sizzling on the pipes as it ran down the front of the bike.
Not sure what color it was...it was dark out.
Old Apr 7, 2008 | 12:14 AM
HEMSPLT's Avatar
HEMSPLT
Some of you guys are way too funny.
I turn my own wrenches. When I grease the steering head bearings I use synthetic grease. It doesn't melt like the crap Harley sells. I make sure there is plenty of new grease to fush out the old and then I take some time and clean up the excess. My question is this - How much grease do you have to pump into the steering head bearing to have it splashing back on the tank and mirror and running down the fork leg? I just can't imagine that much grease in that area.
My vote is for a blown fork seal.
Old Apr 7, 2008 | 12:43 AM
50thStateCycle's Avatar
50thStateCycle
Maybe take the front fairing off to look? Might find fork oil leaking on a green tag or something.
