Trick to get oil filter off
Old Apr 7, 2008 | 10:26 AM
TRS_2000FLHRCI's Avatar
TRS_2000FLHRCI
Default RE: Trick to get oil filter off
+1 on the K&N filters. Before I got the K&N's I used wide jaw channel locks...worked great. But the nut on the K&N is the cat's meow.
And...no, I don't think a K&N filter would void any warranty unless they could prove that the filter caused damage which it won't. The KN-171 is made for the TC-88 and probably several others.
Old Apr 7, 2008 | 10:31 AM
CREEPSHOW's Avatar
CREEPSHOW
I've used the screwdriver method once, messy, but worked!
Old Apr 7, 2008 | 10:32 AM
nridge128's Avatar
nridge128
Hey Dirt, where did you get that ?
Old Apr 7, 2008 | 10:39 AM
scootertramp's Avatar
scootertramp
Do the K&N filter down to 5 micron like the Harley filters?
im's Avatar
im
i bought the correct cup style size at autozone...$4.00
could not get it to work easily..would hit wires etc.
got the dremel tool out..cut straightline on cup from 2 o'clock to 4 o'clock..toss out cut-off piece
basically it looks like the one HD sell with the sensor cut-out...
Old Apr 7, 2008 | 10:51 AM
tlb's Avatar
tlb
+1, I use the same wrench for everything. My boat has three different size filters that have to be changed every fall. I can use one wrench on all off them. Plus the truck, harley, and mower.
ORIGINAL: dirtdobber
I use this. It will get the toughest lose. I have had it for several years now and I haven't found a filter placement that it would not not work with.
Old Apr 7, 2008 | 11:03 AM
Cruise's Avatar
Cruise
I've used strap wrenches, modified wrenches, screw drivers, K&N filters, etc. I finally broke down and bought the Harley oil filter wrench part # HD-44067-A for $9.95 at the dealer. Why I didn't buy it long ago and save myself a lot of trouble I just don't know.
[IMG]local://upfiles/52159/36A89D8982134CC9B11A03DEAF892E9F.jpg[/IMG]
Old Apr 7, 2008 | 12:26 PM
Uncle Scrooge's Avatar
Uncle Scrooge
Channel locks get the Uncle Scrooge seal of approval.
Old Apr 7, 2008 | 01:15 PM
Beemervet's Avatar
Beemervet
Duh...........
Two screws and the sensor comes out of the way.
Old Apr 7, 2008 | 01:20 PM
big_al's Avatar
big_al
Old faithfull has never let me down, there is not a filter this thing won't take off
[IMG]local://upfiles/45508/5BE1CA45E3834F92AC88B2321CFC3301.jpg[/IMG]
[IMG]local://upfiles/45508/10B205A5B64E44E1B4DE1CF520A99DDE.jpg[/IMG]
