Define Wallow....
Old Apr 7, 2008 | 01:30 PM
Bluerose
Guest
Posts: n/a
Default Define Wallow....
I was riding my Ultra about 80 mphon a long down hill sweep (freeway) that is fairly steep...I ride this section of road daily when I commute. The whole bike moved (wobbled) rhythmically down the hill. I have seen several bikes do this (one chopper really bad).
Is this the "Wallow" everyone speaks about?
Or could it be defined as: When I first started riding the bike I felt like the back tire sort of floated once or twice. This was on a straight away with rain "grooves".
Now beforeyou get started I just want to say that I check tire pressure religiously.I have seen several bikes do the same thing down that hill....that was the first time it was a pretty good wobble for me doing about 80...I usually hitthat down hill between 70 and 75.
I at no time thought I would lose controland backing off relieved it. It was nota "front end" wobble or tank slapper.
Old Apr 7, 2008 | 01:50 PM
Puggy's Avatar
Puggy
Default RE: Define Wallow....
Basically, that sounds like a wallow. Probably caused by the stock Dunflops tracking the rain grooves (they are infamous for that). I've experienced the same thing on a flat straight road with the grooves. It got worse the faster I went.
Old Apr 7, 2008 | 01:53 PM
Jumpman's Avatar
Jumpman
That sounds pretty close.
Old Apr 7, 2008 | 02:20 PM
Streetrunner's Avatar
Streetrunner
I have felt it front and back at the same time going straight at around 65-70mph, concrete road, no rain grooves. What started it was a crosswind. I was actually going over a bridge. Felt like I was going down, I just kept a steady throttle and rode it out.
Thankfully it hasn't happened since I installed a TXR stabilizer.
Old Apr 7, 2008 | 02:27 PM
Neil's Avatar
Neil
I described it like the bike having a hing in the middle of it and the the whole frame bent around that hinge point. Just a bit unsettling but nothing to make me panic. My old Gold Wing had the same type of feeling before all new suspension and super brace. I don't feel the need at this point to make any upgrades or changes. I think what you described is the dreaded HD wobble!
Neil
RDMC
Old Apr 7, 2008 | 03:08 PM
RoadKing_Al's Avatar
RoadKing_Al
ORIGINAL: Streetrunner
Streetrunner, with the TXR stabilizer installed, how does the TXR stabilizer effect the changing of the filter?
Old Apr 7, 2008 | 03:25 PM
Bluerose
Guest
Posts: n/a
So is that 80 mph "wallow/wobble" what True Trac is supposed to correct?
Old Apr 7, 2008 | 03:36 PM
dawg's Avatar
dawg
ORIGINAL: Neil
My old Gold Wing........
Neil
RDMC
A Road Dawg with a Gold Wing???? Guess I shouldn't poke fun, we have one winger in the VT chapter.
Old Apr 7, 2008 | 03:57 PM
cwilks's Avatar
cwilks
ORIGINAL: RoadKing_Al
What filter??? Its nowhere near the oil filter....in fact its at the other end of the motor/tranny
Old Apr 7, 2008 | 03:58 PM
Gviertell's Avatar
Gviertell
I experienced that some. But usually on a turn-especially on a rough road. I ride 2-up most of the time. The true track helps a bunch. I had it on my Road King and switched to my Ultra as soon as I got it home. We have a lot of mountain roads with rough pavement. It also helped with what you are describing also. Rather pricey-but easy to put on and well worth it in my opinion.
