Headlight flickering.....
Old Apr 7, 2008 | 05:24 PM
Bigstick's Avatar
Bigstick
Default Headlight flickering.....
Ok so my lately a couple times I turn the ignition on and the low beam is out. However, sometimes it comes right back on and the high beam never goes out. So I replaced the headlight bulb and it still does the same thing. Sometimes going down the road it will just go out and no matter how many times I flip the low/high switch it will stay out until it decides to come back on but the high never does this. Where should I start checking? The switch or the wire?
Old Apr 7, 2008 | 05:40 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: Headlight flickering.....
Ah'd be checkin' the ground wiring....sounds lahk ya've got a floatin' ground tryin' ta find a place ta go.
Old Apr 7, 2008 | 06:28 PM
RangeRat's Avatar
RangeRat
Yep. +1
Old Apr 8, 2008 | 06:12 AM
Bigstick's Avatar
Bigstick
If it was the ground then whouldn't it be doing it on the high beam as well and not just the low beam?
Old Apr 8, 2008 | 06:18 AM
TexasRedneck
You're right. Never mind...don't bother to check it. Dunno why ah bothered with electronics school....
Old Apr 8, 2008 | 08:57 AM
Bigstick's Avatar
Bigstick
No Texas you have a good point always check your ground b/c most of the time that is the problem. I rode all the way to work this morning with the low beam and no probs...what gives!?!?
Old Apr 8, 2008 | 12:03 PM
Bigstick's Avatar
Bigstick
Anyone?
Old Apr 8, 2008 | 03:43 PM
TexasRedneck
If you don't have a good ground, the circuit will do all kinds of crazy stuff ta make one for itself - you wouldn't believe the goofy stuff ah've seen created by a bad ground! A quick an' dirty check is ta run a temporary ground from the battery to the ground side of the headlights an' see if the problem clears.....
Or jest ride in the daylight.<g,d&rlh>
Old Apr 8, 2008 | 05:34 PM
twincam47's Avatar
twincam47
There are only 3 wires going to the headlight plug. low beam, high beam and ground...the ground is common to both the low and high beam....
i would look at the...i believe it is the yellow wire for the low beam......plug connection for the wire is bad, wire is broken somewheredown the line and making intermittent contact or the switch is bad.
I would pop the headlight assembly out of thenacelle/fairing and jiggle the wireswhile the headlight was in the low beam position.....this would be a quick way to see if it is the wire or connection.
Old Apr 8, 2008 | 05:35 PM
choochoo's Avatar
choochoo
high and low use a common ground.
Look at the power wire for low beam.
Also could be a bulb going bad.
Try a new bulb, I normally carry a spare anyway.
