RK Classic
Old Apr 15, 2008 | 09:24 PM
shoveldog's Avatar
shoveldog
Default RK Classic
How the heck does the chrome cover over the handle bar clamp come off? I need to adust the bars. I have asked 4 or 5 people (not techs obviously) met at 2 different dealerships, and no one has been able to tell me yet. It has to come off somehow.
Thanks in advance,
Old Apr 15, 2008 | 09:29 PM
jag1886's Avatar
jag1886
Default RE: RK Classic
The little chrome ring that says lock/unlock where you lock the steering head comes off with a small screwdriver (just pry it up and it pops off) there are three screws under it that hold the cover on.
Old Apr 15, 2008 | 09:38 PM
steelhead's Avatar
steelhead
What he said but there is a bit more to it than that. The chrome "spear" that runs along the top of the nacelle needs to come off and it requires going in through the front behind the headlight.
Old Apr 15, 2008 | 09:43 PM
caleb7mm's Avatar
caleb7mm
1 screw to pull light ring off
8? screws to pull headlight out
1 nut to pull trim off (I think its a 7 or 8MM)
pop cover off lock ring and remove screws
Should take you 5-10 minutes depending on skill level
--c--
Old Apr 15, 2008 | 09:49 PM
SoCal_Pappy's Avatar
SoCal_Pappy
ORIGINAL: caleb7mm
--c--
Watch that little nut inside & top of the headlamp assbly (holds the spear)... It WILL break very easy.. Been there done that
Old Apr 15, 2008 | 10:14 PM
shoveldog's Avatar
shoveldog
Thanks to all. I will try it tomorrow. Seems like its more work than it oughta be, but better I know going in.
Old Apr 15, 2008 | 10:16 PM
SoCal_Pappy
If your going to be in there - You might want to change out the upper handlebar clamp... The OEM is Junk...
Old Apr 15, 2008 | 10:19 PM
RK_Dave's Avatar
RK_Dave
Like the others have said, once you know what to remove, it only takes about 8 minutes. I adjusted my bars, late last year and it made All the difference!
Good luck.
Dave...
Old Apr 15, 2008 | 10:31 PM
Smokeater's Avatar
Smokeater
Yep....Beware of the little screw that holds the spear. It's a pain to get to.
Jamman718
Aug 9, 2014 05:05 PM
bikehunter
Jul 31, 2009 03:52 AM
azdave
Jun 24, 2007 07:17 PM
sbkjo
May 11, 2007 03:44 PM
Reddawg
Jan 4, 2006 02:57 PM
