Help!!!! Big Problem
Old Apr 19, 2008 | 03:01 PM
Daytona Glider's Avatar
Daytona Glider
Default Help!!!! Big Problem
This may not be the place for this but nobody is in the electrical forum. I am half way through running my cables through the handlebars and I decide to check everything on the left side which is the one I just finished. I turn on the switch and nothing. No lights stereo or anything. I thought I might have blown a fuze so I checked every one I can think of and they all seem fine. Someone please tell me what else to check,, I am starting to panic!!
Thanks guys
Old Apr 19, 2008 | 03:20 PM
DamifIknow's Avatar
DamifIknow
Default RE: Help!!!! Big Problem
Battery reconnected?
Old Apr 19, 2008 | 03:27 PM
sifularson's Avatar
sifularson
Did you unhook the battery before you started?
Or at least did you pull the master fuse?
I looked in my manual for you and you must have blown a fuse. If you have a 12 volt tester, you can check the fuses. They are all located under the side cover.
Simon Rodriguez
Sep 6, 2016 07:58 AM
Cstevens87
May 15, 2012 01:12 PM
rick
Dec 11, 2010 09:37 PM
ivnurse
Oct 9, 2010 01:09 PM
joshuri
May 31, 2007 11:17 AM
