Need jet suggestions for carb re-work.
I am a happy fella.
I'm sure there will be a bit of tweaking that I need to do - but the bike runs a TON better than it did since I put the new breather on.
I went to the local sho around lunchtime and grabbed a #45 slow jet. Came back to the house (I work from home a couple of days a week) and installed it. Whole process took about 25-minutes - It woulda been done in 15 if the stock jet woud have played nice - I ended-up having to bend a screwdriver so i had enough leverage to break the jet loose. It DID NOT wanna come out.
SO.. screwed the new jet in place - and ran the bike up the street for a quick test (less than am mile total) and I am now smiling as I am printing my reports.
It's the little things that really can change your day.
buy the dynojet kit.....change the spring, drill the slide, punch the air/fuel slow speed plug and adjust according to instructions,change the needle as per thier instructions, change the pick up tube and install the 195 main jet along with a 48 pilot jet (pilot jet is not included withe the kit). This kit is complete with all parts (except pilot jet) and includes drill bits for drilling where indicated.
I am a happy fella.
The indy said they normally don't have to change the main jet when they do breather/exhaust. One of the sites I did research on said the same thing.We'll see how it rides on the Hwy & I'll makeany necessary changes later.
I am just glad to have something that is (very) ridable. The rest will just be some fine-tuning.
The first thing to do is make sure the mixture screw is uncovered , once it is you can adjust it slightly.
Usually you will need a bit more than it will give you this way.
If you do in fact have a #42 pilot jet , then going to a #44 (stock sportster)or #45 (stock newer TC) would probably work for you.
Mine was stock at #45 so I went to a #46 for a while then to a #48 which worked well for "my bike".
I picked up a couple jets locally and one from JP Cycles catalog.
Once you have the idle where you want it to be , shimming the jet needle helps a bit for more rpms in the power curve.
I played with 1 shim then 2 and it got better each time.
I finally went with a 27094-88 (sportster needle) longer taper/slightly smaller diameter , and was better still.
Ran better and the fuel mileage went up slightly.
The main jet (mine was a #190) is fine , I went up to a #195 and the fuel mileage dropped of slightly , so it's a bit too much actually.
The EPA isn't real concerned with full throttle , so the stock main is fairly close as is.
Just pay attention to how it runs and read the plugs , do one thing at a time so you know it's repeatable , and you'll get it right.
The stock CV carb is pretty easy to work with , and takes to jetting changes very well.
I only use stock spark plugs , if you don't , just make sure you keep the same ones all the time , as you will get another variable in your tuning.
Good luck
Mick
If you're just getting started with jetting the bike , knowing the baseline is helpful.
Good luck
Mick
I still have not had a chance to get out and 'really' ride the bike to see how the changes impact mid-range & top-end power. I've kinda been locked into subdivision for my test rides - as I don't wanna leave my daughter home alone too long.
IFrom what I have seen so for - I think the move to a #45 slow jet (from a #42) solved 90% of the problems I was having. I did a little more research last night, and I think that adding a washer or two will get me to where I want to be. I should have a good balance of performance (slightly better than stock) and still get good fuel economy.
I have not yet removed the plug for the idle/air screw - as all the work I have done so far has been with the carb still on the bike. So - we'll see how it all works-out once I do that. I also want to get a new set of plugs to before I start messing with it anymore. I shoulda pickedthem up yesterday - but it slipped my mind.
I managed to drill the cap (real carefully) without removing anything on the bike.
Make a note of how many turns in till the stop you have , and be gentle.
Just set it for the best idle at 1000 rpms (or whatever yours calls for).
You should stop there and run a few tanks through and do a fuel mileage average.
Read the plugs and see if they're a bit lean (white).
The #45 pilot will take care of your idle and just off idle circuit.
The exhaust note should be more stable and and the engine slightly cooler in traffic.
After a few tanks , see if the throttle response is just a pinch lazy higher up the throttle range.
I ran about 50 mph in 5th and turned the throttle maybe 1/16" "more" and it did nothing.
Then turned it about 1/16" "more" and nothing , the next 1/16" did something , so the power was slightly flat (lean) in that range.
That's when I added 1 #4 machine shim under the jet needle.
Tested again and got better response at the second 1/16".
Then added 1 more #4 machine shim and got response at the first 1/16" of throttle movement.
This may do it for you and I could have stopped there.
The sportster needle did just a pinch (and I mean Pinch)better so I stopped there and am happy.
Great mileage and performance for about $20.00 and some time , a pretty good deal nowadays.
Good luck
Mick
