Sore neck, new handle bars?
Old Apr 21, 2008 | 06:16 PM
05Fatty's Avatar
05Fatty
Default RE: Sore neck, new handle bars?
ORIGINAL: FLFOOL
In addition to Merlinii's comments you should have someone look at your posture from the side, as you sit in your riding position. You may need a backrest to get a straighter line up your spine and cervical vertebrae. YOur seat should be of a design that will help with this too. I've found over the years that a flatter and more level seat works well for me.
Forward controls or a short person on a FL model can result in an unnatural position.
If your bars have you pulling your torso forward your neck will curve the same as if you are riding a crotch rocket. Therefore you may not want apes. The most relaxing position will be with your hands just above your knees (longitudinal position) as in sitting at the dinner table and a height that puts your elbows just forward of your torso and almost level. Be aware that the width of the bars can influence comfort too. A lot of riders think only of the image they want to project and not the comfort or safety.
If you are wearing a helmet, get the lightest one you can find. The Harley carbon fiber 1/2 is the lightest one I've found that will also protect at least a bit of your head.
You may want to spend some time in a showroom where you can sit for several minutes on different models. If you neck is hurting on one, you may notice some minor improvement on another and that can help with ideas.
Thanks for the ideas. I don't wear a helmet so that isn't the issue. I'm pretty sure I'm leaning too far forward to reach the bars.
Does anyone know the rise and pull back of the stock bars on a 2006 Ultra?
Old Apr 21, 2008 | 06:26 PM
Hedog's Avatar
Hedog
I put the wild one 16's on my Road King, they killed my upper back and neck area. I then put the Carilini 16's on and it was night and day, no more pain (weird)! I also went with a police air seat. Did 600 mile days going to Sturgis no problem. Like has been stated, go down to the local hangout and if you see some bars that you like, ask the owner if you can sit on the bike......
Old Apr 21, 2008 | 06:33 PM
RonH's Avatar
RonH
I put Wild One Chubby 575's on my 06 EGC and they are great. But the first thing you might want to try is a backrest - just something holding your lower back in so you can't slouch makes all the difference in the world.
Old Apr 21, 2008 | 07:25 PM
harleybodei's Avatar
harleybodei
So how hard is it to adjust the handelbars? do you just loosen the screws and rotate them?
Old Apr 21, 2008 | 08:07 PM
STROKER102's Avatar
STROKER102
I have the same problem with my 07 Street Glide.I get neck pain after a long ride.I am really considering 13" Apes.It will put me in the same position as my 07 Streetbob,wich I can ride all day with no pain.
Old Apr 21, 2008 | 09:23 PM
izzi's Avatar
izzi
x2 on a backrest. you will never NOT use it once you get one. as far as bars with stock cables:Khromewerks 300505 bars and chubby wild 1's #575 will "work" with stock cables. at least a backrest will buy you some time so you make the right decision on the bars.
teedubbyaw
Feb 17, 2017 02:47 PM
EZGOIN
Apr 2, 2008 09:05 PM
07FLHRCMarinePatriot
Feb 15, 2008 12:59 AM
Yellotang
Dec 21, 2007 10:11 AM
toneman
Jun 26, 2007 12:32 AM
