Hoglite install with pictures
Old Apr 23, 2008 | 11:08 PM
capt_caveman's Avatar
capt_caveman
Default RE: Hoglite install with pictures
ORIGINAL: sifularson
ORIGINAL: capt_caveman
I've been looking at this lite but I'd like to put something on the top of the tourpack. I have the luggage rack installed and I'm not really fond of the spoiler. Is the angle of the light adjustable at all or are the mounting brackets 'fixed'?
They are fixed. I held it up to the top of my tourpak and found that it wouldn't mount correctly because the mounting ends won't flex to match up with the curve of the tourpak lid. It will only mount on a flat surface. I suppose a person could fab up some kind of black plastic spacer but that would be the only way to make it work IMO.
Thanks. That helps a lot.
Old Apr 23, 2008 | 11:11 PM
greg09997's Avatar
greg09997
Looks Good..... Sure cheaper than my LED Spoiler.
Old Apr 23, 2008 | 11:21 PM
gman's Avatar
gman
I bought something similar from: http://www.customdynamics.com/Light_bars.htm#Ultra_LED_Light_Bars_
It is a smaller LED bar light that I put on the spoiler on my Bushtec trailer for a 3d Brake light. Really easy to install. It uses a sticky adhesive back that doesn't require any drilling. for something a bit smaller this is an option.
Old Apr 24, 2008 | 07:21 AM
Trapskelly's Avatar
Trapskelly
ORIGINAL: Trapskelly
The plug is a 3 position plug although you only use 2 with the hoglite. One for hot and one for ground. Here are the part #s
(1 each) Tab housing, 3 position - P/N 73103-98bk
(2 each) Tab terminal, P/N 73190-96
Parts cost about $3
From one Steve to another, Thanks.
Steve Kelly
Old Apr 24, 2008 | 07:24 AM
Trapskelly's Avatar
Trapskelly
Hey thanks SOOS, man you are FAST with a camera!
Old Apr 24, 2008 | 07:32 AM
IBHarley's Avatar
IBHarley
http://cgi.ebay.com/ebaymotors/15-5-...2254QQtcZphoto From ebay used double sided tape and 2 smal screws to mount under the tour pack cheaper than Hog Lite
Old Apr 24, 2008 | 10:12 AM
capt_caveman
ORIGINAL: gman
gman, Are you using your lite as a brake lite only or also as a running light? I'm wondering how much intensity difference there is.
Old Apr 24, 2008 | 02:27 PM
sifularson's Avatar
sifularson
ORIGINAL: gman
The Hoglite would be too bright for use as a running light. It would look like your brakes are on all the time. This is just my opinion.
Old Apr 24, 2008 | 02:30 PM
sifularson's Avatar
sifularson
ORIGINAL: IBHarley
This is a good looking unit. The hoglite has ends on it for mounting which make it stand out a little from the tourpak. This is the only reason it might work better.
Old Apr 24, 2008 | 02:44 PM
capt_caveman
ORIGINAL: gman
I agree with you about the HogLite. I'm curious about the lights from CustomDynamics.Com Some of them claim to be wired for dual intensity.
