Popping and backfiring
Old Apr 27, 2008 | 08:03 PM
Beercan321's Avatar
Beercan321
Default Popping and backfiring
I recently purchased a fuel injected 2005 Road King Custom with a Stage II Big Bore add-on. The bike runs fine but I constantly get popping and backfiring out of the exhaust when I let off the throttle. The bike also has Reinhart True-Duals. I initially thought the popping and occasional backfire was fairly normal due to the engine work and pipes. I just rode with a guy that had a lot more engine work than my bike. His bike purred like a kitten. Now I assume the popping is not normal and something is wrong with my bike. Is the popping and an occasional backfire doing any damage to my bike? Anyone have any suggestions as to what I need to do to get the popping/backfiring to stop when I let off the throttle?
Thanks
Old Apr 27, 2008 | 08:13 PM
Ozoneman's Avatar
Ozoneman
Default RE: Popping and backfiring
My 2006 Ultra does the same thing. I've been told it is OK. Mine popped so much when I let off the gas, I bought the SERT and had it dyno tested because I wanted to make sure it was set up right. I bought it used and I wanted to make sure it hadn't been messed up. After the dyno tune I think it pops even more now. I've been told that my Sampson Ovals are nearly straight through pipes and popping is normal on straight through pipes.
Old Apr 27, 2008 | 08:38 PM
Bigredone's Avatar
Bigredone
It shouldn't do any popping if properly dynoed. Check for exhaust leaks at the header and exhaust connections.
Old Apr 27, 2008 | 09:07 PM
Ozoneman's Avatar
Ozoneman
The guy that did my dyno is very experienced and he says otherwise. Are your pipes straight through pipes or do they have baffles?
Old Apr 27, 2008 | 10:21 PM
wedwards's Avatar
wedwards
I am no master wrench by anyones stretch of the imagination, but I always thought that popping and backfiring (especially on deceleration) was caused by excess fuel burning up in the exhaust (causing the popping). Assuming there are no leaks in exhaust as already suggested, proper configuration of your fuel management is supposed to resolve this issue. No offence to Ozoneman or the guy that "is very experienced", but I am thinking that if you are taking your bike to someone to have them fix this issue, you may not be in the best position to judge whether he is experienced/qualified or not. Sounds like they couldnt fix it so its deemed "normal" as it wont hurt anything much and is just annoying. If it was me, I would get a second opinion, as I had the same problem and one dealership couldnt fix it, but the second one did - turns out my fuel management was slightly off because when it was done there was a crack/split in a hose somewhere. Once that was fixed and it was reset and re-dyno'ed it was a completely different bike and no more popping.
Old Apr 27, 2008 | 10:37 PM
Deez's Avatar
Deez
3rd Gear
My 05 Road King with Reinhart Tru Duals was popping alot too. The dealer found a fine crack tin the exhaust pipe off the rear cylinder. He said it was a factory defect that Reinhart is aware of. Reinhart replaced it for free. It took care of the popping.
Old Apr 28, 2008 | 02:44 AM
winston chopper's Avatar
winston chopper
Yes sir , that usually means there is a problem or its not tuned in very well. I have strait pipes on my s&s , no baffles and it pops once in a while not constantly.
Old Nov 8, 2008 | 06:50 PM
Ozoneman's Avatar
Ozoneman
No offense taken.
My experienced guy took time to research the issue. His experience lead him to resolving the problem. He found that adjusting a setting in the SERT solved the problem. He took the time to call me and ask me to bring my bike back in. There is no popping now when decelerating.
Old Nov 8, 2008 | 07:29 PM
beary's Avatar
beary
+1
Beary
Old Nov 8, 2008 | 07:41 PM
dreamcatcher2007's Avatar
dreamcatcher2007
Default How do I check for these leaks?
I just threw a rag over the mufflers and hit the throttle a few times at idle? Is there something else I should be doing?
