RK windshield cut down
Old Apr 29, 2008 | 02:39 AM
JonnyD's Avatar
JonnyD
Default RK windshield cut down
Anyone do the DIY windshield cutdown? I need to shave off an inch, and was just wondering how it turned out for you?
Old Apr 29, 2008 | 02:43 AM
kwoozn's Avatar
kwoozn
Default RE: RK windshield cut down
I'm heading for the search button here myself!
I recall a DIY involving the Road Glide windshield.
Tape, fine tooth jig saw blade, etc.......
Needing to mod mine!
Old Apr 29, 2008 | 10:23 AM
tna1000's Avatar
tna1000
I cut mine. I used a rotozip to cut it then took a sander and smoothed it up. Looks reel nice IMO. Cant tell unless you really study it for awhile.
Old Apr 29, 2008 | 10:24 AM
gordo24fan's Avatar
gordo24fan
cant tap plastics do this too
Old Apr 29, 2008 | 10:30 AM
Akitakoi's Avatar
Akitakoi
Trace the shape of the top curveon a piece of poster board, cut it out. Line up the template and slid it down an inch and tape it down. Use a jigsaw and just follow the template. Sand it smooth by hand or aome kind of electric sander.
The poster board will protect your shield from getting scratched from the saw.
I used blue painters tape to hold the template down.
Old Apr 29, 2008 | 12:21 PM
bacon225's Avatar
bacon225
I cover the whole windshield with masking tape then track out the shape I want to cut.
With acutoff wheel or jigsaw cut slowly and carefully file and sand to finish the edge.
Old Apr 29, 2008 | 12:48 PM
bdr's Avatar
bdr
I did as many have mentioned here, but first I used an old set of dividers like we had in grade school metal point on one side and pencil on the other, I ran that to copy the main curvature, however no matter how you trace the curve you will find a little free hand design work as you need to flare the curve to the outside again. This is very easy to do by the way. I used the blue painters tape as mentioned and followed thelight pencil line with the tapeand covered a good portion of the windshield with some paper and tyvek ( I had it laying around, it's house wrap) I cut with a metal cutting jig saw blade and went slow and tried no to veer off track. I then sanded with very small belt sander with fine sand paper, then polised by hand with a 600 grit and a small block all the way to 1000 grit wet and dry...
You would never know it was done....
One thing that you should be sure not to do is cut too much at one time, I felt I needed 2" off. I cut mine twice, but end result is I should have rode for awhile, I ended up using a different seat and it is higher so now I get some glasses flutter.... One inch would have been just fine
Story of my life, wish I had another inch.... LOL
Anyway, hope it helps, good luck.
BDR
GPHDXLC
Long Ride Shields
Jan 7, 2011 01:54 PM
az232
Mar 28, 2008 07:28 PM
az232
Mar 21, 2008 08:33 PM
brandanfinn
Apr 11, 2007 12:34 PM
Garrynky
Apr 27, 2006 07:19 PM
