Tour pack quick detach kit
Old Apr 29, 2008 | 01:23 PM
Pheebo's Avatar
Pheebo
Default Tour pack quick detach kit
I need some help with a tour pack mount. I bought it off ebay so it came with no instructions. I have not looked at on close up. If anyone could please post pictures or instructions for install it would be alot of help. 1999 Ultra.
Phil
Old Apr 29, 2008 | 01:34 PM
wildrider's Avatar
wildrider
Default RE: Tour pack quick detach kit
if it is a detachable rack, you will need the docking kit.should mount up easy with the proper docking kit. (docking kit is a b###h to put on
Old Apr 29, 2008 | 02:16 PM
Pheebo's Avatar
Pheebo
The docking kit is what I am trying to install. Thanks for the reply.
Old Apr 29, 2008 | 02:33 PM
n.o.yat's Avatar
n.o.yat
i just installed a quick release w/ tour pac on my 08 streetglide. i thew the h-d instrutions away and just fit everything where i thought it would go. a piece of cake , it took about 1 1/2 hour to do complete job.
Old Apr 29, 2008 | 02:39 PM
EasternSP's Avatar
EasternSP
If you have the complete docking kit, you should be able to hold the rack itself up to the side of your bike and see where the mounting bolts should go in your rear fender supports. The narrow slotted bolts go forward and the ones with the wider nylon inserts go to the rear to accomodate the release levers.
Old Apr 29, 2008 | 02:43 PM
mnr60's Avatar
mnr60
Try using the search, lots of posts on this.
This one might help. https://www.hdforums.com/m_2091902/tm.htm
Old Apr 29, 2008 | 02:51 PM
AISTQM's Avatar
AISTQM
I have a set of instructions I would be glad to FAX to you. Pm a number if you want them.
Old Apr 29, 2008 | 03:18 PM
2003flhtci's Avatar
2003flhtci
I'm not sure how well this will work...3 pages of instructions...
Old Apr 29, 2008 | 04:42 PM
Meist21's Avatar
Meist21
Throw away the instructions..............Look around the search section for good pics.............that's all you need. Those HD instructions suck...........................
Old Apr 30, 2008 | 08:53 AM
Pheebo's Avatar
Pheebo
I think I have narrowed it down to inst. for a 1999 to 2003. I think they changed after that. I got the rear brackets on(the U shaped ones). But the front brackets look like the should go right behind the shocks and the brackets I have don't fit there.
