air force master blaster?
Old Apr 30, 2008 | 11:29 AM
2011 Road Glide Ultra's Avatar
Default RE: air force master blaster?
ORIGINAL: twistedcherokee
http://www.worldpetstore.com/meairfomabld.htmlHas it for the 279.95. Has free shipping if you follow the instructions up to 20 lbs. Not tsure if it applies on the MB.
Toby
Shipping from them shows $22.95 to me - it's overweight.
Old May 3, 2008 | 09:43 AM
twistedcherokee's Avatar
twistedcherokee
Then Groomers.com would be the better price.
Toby
Old May 3, 2008 | 10:01 AM
ChiefGator's Avatar
ChiefGator
I use my compressor with a blower and nozzle attachment. For the same price you can get a good sized Craftsman set up that comes with the nozzle. Then you get the added bonus of being able to use it for other things. Most of the basic kits come with a tire inflation valve, if nothing else, you can do your own tire checks without having to head to a gas station.
Way too much money for a single use tool.
Old May 3, 2008 | 10:23 AM
tgaetto's Avatar
tgaetto
ORIGINAL: ChiefGator
+1
Old May 3, 2008 | 10:25 AM
Lord Albany's Avatar
Lord Albany
ORIGINAL: tmblweed
Hey, I traded an 06 Vulcan Classic for my FLHTC...it was a really nice bike.
Honey bees are dying in large numbers.
Old May 3, 2008 | 10:40 AM
max56's Avatar
max56
Veteran: Coast Guard
I've got a similar (but better) type of dryer that utilizes two motors and 8 horsepower. I originally bought it for dog grooming, which I still use it for, in addition to bike duties. I love that thing. Even with both motors running, it still takes at least half an hour to dry my dog. I couldn't imagine trying to get the dog to sit there and get the same task accomplished with a leaf blower. The dog would end up deaf.
With that said, I really don't see much of a reason why you couldn't use a leaf blower on a bike. I doubt the air can be focused near as precisely, but eventually the end result will be the same. I wouldn't use an air compressor...unless you had means to filter out the moisture that accumulates in the tank.
Old May 3, 2008 | 10:50 AM
max56's Avatar
max56
As far as the air compressor goes, when I drain the tank on mine, the water has what looks like rust from the inside of the tank in it. When I use air tools for extended periods of time, that water starts coming out of the tool I'm using. There's no way I'd want to spray rusty water on my Harley. Something to think about. A good filtration system would fix that, I suppose.
Old May 3, 2008 | 11:05 AM
ChiefGator's Avatar
ChiefGator
ORIGINAL: max56
If moisture were a real issue, paint sprayers would not be very effective.
Technically, you should empty your tank after each use with the relief valve on the bottom to ensure no moisture build-up. That will keep your tank from rusting.
I have mine set at 120psig shooting through a 1/16 inch nozzle. Even if moisture were present, it would be atomized to the point of being a non-issue.
You are using it to dry a bike, not custom airbrush work.
Old May 3, 2008 | 11:20 AM
max56's Avatar
max56
ORIGINAL: max56
Hey Chief...if you're draining the tank after every use...obviously moisture is accumilating in the tank or nothing would drain out, right? I may only get an ounce of liquid out of my tank after usage, but it has a reddish tint to it. Regardless of how fine it's atomized...it's still going on the bike. And anyone who paints with an air compressor uses filters to filter out moisture. They're not cheap.
Old May 3, 2008 | 11:36 AM
Geoff's Avatar
Geoff
I use this $49 JC Whitney cycle dryer. Works great.Why spend more?
