GPS LOOSES POWER/QUESTION
Old Apr 30, 2008 | 05:35 AM
TOMCENTRAL's Avatar
TOMCENTRAL
Default GPS LOOSES POWER/QUESTION
I have a Garmin Zumo 550 & have it wired to the acc out on my 08 Ultra.Garmin is sending me a replacement wire & they have replaced the handlebar mount as they had a few of them that were defective.My problem is when I hit the front brake comming to a stop or just setting still the unit looses external power & switches to the internal battery(the unit states 'do you want to continue on the internal battery?')I remember a similar problem on my 05 (also w/security) TSS after installing a Corbin heated seat that caused the stop lite to stop working & the dealer needed to reprogram the TSS in order for the heated seat & lite to function properly.Anyone out there have a fix or had a similar problem?Thanks in advance & regards,Tom
Old Apr 30, 2008 | 06:26 AM
workformetoo's Avatar
workformetoo
Default RE: GPS LOOSES POWER/QUESTION
"I have a Garmin Zumo 550 & have it wired to the acc "
Try wiring direct to the battery to rule out some kind of problem with that conection (maybe put a meter on that wire and watch for a voltage drop when brake is applied). What could be happening is, your FOB could be interupting that circut for just a second (just enough to cause it to go to the battery mode). Temporarily hooking direct to the battery will rule that out.
Old May 1, 2008 | 01:27 AM
TOMCENTRAL's Avatar
TOMCENTRAL
FOB?do you mean key fob?Regards,Tom
Old May 1, 2008 | 01:35 AM
Casper's Avatar
Casper
try the battery hook up, might be loosing connection on the mount, try some electical contact cleaner on the mount...
Old May 1, 2008 | 03:51 AM
troutbum1971's Avatar
troutbum1971
www.zumoforums.com
but i have mine wired to the back of the cig lighter on my 08 Ultra, 0 problems to date...
Old May 1, 2008 | 04:01 AM
BirchwhiteHD's Avatar
BirchwhiteHD
I also have mine wired to the back of the cigg lighter,word flawlessly,no problems as of yet
Old May 1, 2008 | 05:40 AM
nutflush607's Avatar
nutflush607
ORIGINAL: TOMCENTRAL
Im having the same problem, I'm hooked up directly to the battery. Every time I come to a stop until I put some throttle in it, the unit stays on battery
Old May 1, 2008 | 05:49 AM
troutbum1971
go to radio shack buy 2 connectors, cut off the connectors at the back of the cig lighter... twist cig wires and gps wires hook into new radio shack connectors plug back into lighter....bing your done.......
oh yeah take off outer fairing first...... would have taken me 30 minutes but my dumbass wanted to check power first and shorted out a fuse by touching the lead of my meter to both posts on the cig lighter.... so you throw in the time it took to find a new fuse and all it was about 16 hours..... all the stores were closed....[:@]
Old May 1, 2008 | 08:35 AM
gman's Avatar
gman
ORIGINAL: BirchwhiteHD
+2. My 2610is wired to the back of the lighter also, works great with no problems.
[IMG]local://upfiles/12616/65C8840AEBB34F7CB13584BBCA164A1B.jpg[/IMG]
Old May 1, 2008 | 02:19 PM
casique's Avatar
casique
I have the same problem power goes from the bike to the internal battery. I just got a new craddle from Garmin, but have not tested it. I have mine hooked up to the accessory plug under the seat using the HD pigtails.
garywi
Dec 31, 2014 05:19 PM
carcruizer1955
Jan 17, 2014 10:07 AM
924shane
Apr 12, 2010 12:13 PM
TOMCENTRAL
May 1, 2008 01:26 AM
mhud
Apr 4, 2008 07:02 PM
