Headlight Visor Trim Ring Gap
Old Apr 30, 2008 | 11:56 AM
jsimo7's Avatar
jsimo7
Default RE: Headlight Visor Trim Ring Gap
I'll live with the gap for 325.00
Old Apr 30, 2008 | 12:14 PM
SCRider's Avatar
SCRider
Not only did my HD trim ring have the gap, but it also whistled in the wind. I had that damn HD trim ring on and off many times trying to get it right.
I finally decided to get the Headwinds Trim ring, and wow what difference. One piece billet and super easy to install. Here a a couple of Pics. I went with the Vampire Trim ring.
Old Apr 30, 2008 | 12:19 PM
drfeelgood's Avatar
drfeelgood
I also have a gap, thought it would drive me nuts. With time I have found I don't even notice it anymore.
Old Apr 30, 2008 | 12:21 PM
Sgt Mac's Avatar
Sgt Mac
No gap. loosened the original ring, slipped the back of the visor ring behind it, tightened the original ring, tightened the visor ring.
Old Apr 30, 2008 | 12:42 PM
Big Peter's Avatar
Big Peter
ORIGINAL: SG 1
After reading here of the problems with the HD Visor ring, I ordered one anyway hoping I would get lucky. No such luck, I have the dreaded gap.
Does anyone know if someone else other than HD makes the visor ring? I can live with what I've got if I have to, but would like to explore theoptions.
I've done the search thing, and in some old posts, it was said that J&P has them, but I can't find one there. I put a piece of chrome pin stripe tape over the gap as someone else here has done. It looks better than the gap but I can still see it even if no one else notices.
Got my frenched headlamp trimring from Custom Chrome (NO GAP)
You might try to loosen the stock ring a bit more
it took me about an hour to get it right.
Good luck
Peter
Old Apr 30, 2008 | 01:15 PM
patsfan's Avatar
patsfan
These must be made inconsistently. I just returned the visor ring the other day because of the gap. Fussed with it about an hour, scratched my stock ring[:@]then finally said F'it. I even took the stock ring off and fitted it inside the trim ring, the trim wouldnt even close that way, the stock ring was too big. I tried all the above mentioned solutions with no success, congratulations to those that got a good fit.
Old Apr 30, 2008 | 02:58 PM
chiefparry's Avatar
chiefparry
No problem with mine. +1 what Evil said:
[IMG]local://upfiles/46029/C52C964782C843F2AAA9D01A4D2A1649.jpg[/IMG]
Old Apr 30, 2008 | 03:04 PM
glide's Avatar
glide
If you loosen the stock ring screw enough. the gap closes up.
Old Apr 30, 2008 | 03:06 PM
BigDaddyMike's Avatar
BigDaddyMike
No gap, I followed the instructions very carefully
Old Apr 30, 2008 | 03:12 PM
BillinNY's Avatar
BillinNY
Hey BigDaddy,
You have a copy of those instruction that you can post?
-Bill-
