engine light
Old Apr 30, 2008 | 02:45 PM
patsac's Avatar
patsac
Default engine light
comes on every now and then..but only in 6 gear...i can give it some throttle or back off some and the light goes off.....code number is 1353...any ideas on what its tellin me?
Old Apr 30, 2008 | 02:58 PM
glide's Avatar
glide
Default RE: engine light
P1353 Front Cylinder No Combustion EFI
Check your plug wire and plug.
Old Apr 30, 2008 | 03:02 PM
hogbag07's Avatar
hogbag07
P1353 (efi)
Front cylinder no combustion.
Cylinder is truly misfiring.
There is a lack of continuity in the ignition coil secondary circuit.
From a 2007 electrical manual
Old Apr 30, 2008 | 07:03 PM
patsac's Avatar
patsac
wouldnt i feel the lack of power if there is no combustion? cause i dont..it doesnt miss a beat..i dont feel nothing nor do i hear any difference from the pipes
Old Apr 30, 2008 | 07:09 PM
Skivvy9r's Avatar
Skivvy9r
Arguing with the code won't help. Your system thinks it's misfiring. Check the connections and go from there.
Old Apr 30, 2008 | 07:53 PM
glide's Avatar
glide
ORIGINAL: hogbag07
You may be setting the code because of the ION sensing in the system. It's not actually misfiring but the resistance is not within parameters so you get the code.
Old Apr 30, 2008 | 08:47 PM
confused's Avatar
confused
I have 800 miles on my 08 Ultra and my light is coming on some days
I ride and no light for two days then it is on all day
The dealer has checked it over twice
How many times do they get before I can say something to someone
philb252
Sep 10, 2013 09:26 AM
lonelyrider1966
Sep 3, 2013 07:49 PM
Rubber Slinger
Apr 2, 2010 09:17 AM
sparky_mo
Sep 12, 2009 05:38 PM
sparky_mo
Sep 12, 2009 08:15 AM
