Did I Remove Too Much?
Old May 1, 2008 | 07:03 PM
Moby's Avatar
Moby
Default Did I Remove Too Much?
My outer faring is due at the painters tomorrow. After reading the service manual and getting some help from forum members, I figured it should be an easy job to remove the fairing, and things were going great, until that is the last step when I had to disconnect the headlight. What I didn't factor in was that I had the HD HID installed by the dealer before I took delivery of the bike. After following the service manual directions, I couldn't find the connector to disconnect the headlight. After puzzling over this for a while, I pulled out the directions for installing the HID. I ended up removing the headlight so I could find the connectors for the two bulbs. Does anyone know a better or easier way to do this?
Old May 1, 2008 | 07:38 PM
07blackcherryflhx's Avatar
07blackcherryflhx
Default RE: Did I Remove Too Much?
Does the hid set-up plug into the normal socket or is it a complete rewire for the HID light. My dual beam just plugged in a worked great. I love that light
Old May 2, 2008 | 05:14 AM
Moby's Avatar
Moby
The Harley HID has an extra wiring harness to connect the HID bulb to the ballast. The high beam uses the stock headlight wire.
AK47
Jul 25, 2013 12:14 PM
Wakko47
Jan 10, 2013 01:33 PM
Stanger
Aug 1, 2011 01:06 PM
LarryJ00
Jul 18, 2007 11:03 PM
pat112
Jul 22, 2006 10:07 PM
