Is this a normal oil leakage?
Old May 5, 2008 | 03:36 PM
SCRider's Avatar
SCRider
Default RE: Is this a normal oil leakage?
ORIGINAL: Dago_RoadKing
You would not by chance have a K&N or K&N like filter which requires filter oil would you? I have seen people put to much oil on the filter after a service, and it gets a thin layer of oil all over the parts in that area. The problem that I am talking about is quite common.
+1 on that. Looks like too much air filter oil.
Old May 5, 2008 | 03:38 PM
aksv's Avatar
aksv
Hello Dago_RoadKing
Yes, I have a K&N filter. So maybee I should check the filter also. I don't know how much oil there should be on the filter, but I suppose it shouldn't be dripping. I will check it tomorrow to.
Thank's for your comment.
Old May 5, 2008 | 05:43 PM
jack49's Avatar
jack49
Wash filter,let hang and dry overnight.
Lay filter flat and spray lightly with oil, ONE SIDE ONLY
If you missed any spots,lightly touch up with oil spray.
Hang filter and let any excess oil drain off.
I've never had any air filter oil leakage problems,when done this way.
LDR
Aug 8, 2012 08:59 PM
skip3406
Apr 5, 2012 10:38 PM
Badass67stang
Sep 26, 2010 09:02 PM
WARG
Dec 28, 2008 05:45 PM
WARG
Dec 28, 2008 02:16 PM
