How easily does YOUR rear tire lockup
Old May 7, 2008 | 10:18 PM
  #61
Ultra007's Avatar
Ultra007
Default RE: How easily does YOUR rear tire lockup
Paniolo is absolutley right. 70 / 30 at most!!
The biggest problem is when "the first response or reaction is to hit the rear brake". There ya go! If the rear is your first reaction, you had better practice much more. IMO Practice until the first reaction is to grab a hand full of fronts. Then you feather the rear to COMPLIMENT the stop, not CREATE IT.
If you can still see windshield on a hard stop, you haven't used enough front. If you start with the rears, you'll never catch up with the fronts.
Also, be aware that the bike will behave much differently if the tour pack is on or off or two up / one up. It all takes practice and time.
U
Old May 7, 2008 | 11:52 PM
  #62
ratcat's Avatar
ratcat
This guy is good with words, but better with his advice...good job!
The only other thing I can add is, practice braking on differant road surfaces, sure...wet or dry, but I mean assphalt, chipseal, concrete or even gravel.
ORIGINAL: Paniolo
Folks here have given some good advice.
In an emergency stopping situation, some ridersrevert back toI call "driving the car". They do on their bike what the do in their car, which is jam on the brake pedal and forget all about the front. Their instincts become more car, than bike. This can lead to rear wheel lock up. So I tell riders they should practice threshold combination braking. The application ofboth brakesright up to the thresholdof imminent lock up. I always use both brakes because the bike has two sets of independant brakes on them. Perhaps the rear only accounts for 20-30% of stopping power, but that's thats 20-30% more than if I didn't use them. And remember, when you apply BOTH brakes, the front, (which has over 70% of the stopping power), will cause the front end to dive andthe forks to compress. And as the front end gets heavier and goes down, the rear gets lighter and comes up. Hence the rear will have a greater propensity to lock up. So you need to be able to modulate your rear pedal to avoid the lock up. Of course the only way to become proficient at this is REGULAR practice. Make practice part of your riding routine. Factor in 10 extra mins before the ride to practice braking and other skils.
And like the others said. If you lock up the rear STAY ON IT AND KEEP IT LOCKED UNTIL YOU COME TO A COMPLETE STOP.
Old May 8, 2008 | 01:46 AM
  #63
davewear's Avatar
davewear
if you crash because you locked up the rear you f**k'd up! get out in a parking lot and practice braking.....
Old May 8, 2008 | 05:03 AM
  #64
XTrooper3936's Avatar
XTrooper3936
ORIGINAL: harry.b
When I first got the bike I was in a panic stop situation and stepped on the rear and started skidding. I grabbed the front brake and let off the rear with no mishap. I would say that the rear locks up way too easily. Never experienced that on another make of motorcycle.
You can get away with letting off the rear brake with the rear tire skidding only if the bike is still relatively straight and/or you're traveling at very slow speeds, but if the rear is locked up, your bike is out of shape, and let off, the rear will snap back and you will high side. High-siding is never good and is almost guaranteed to cause serious injury. This is why you should do your best not to lockup the rear tire because once it starts skidding, you have to ride it out and not let off because the alternative is worse. Better to low side (lay it down) than to high side and do the human equivalent of a plane crash.
Old May 9, 2008 | 05:32 AM
  #65
ditch_dgr's Avatar
ditch_dgr
My rear tire never locks up unless I do it on purpose, and I have only done that once. I follow the information presented to me in the motorcycle safety course, I always use both brakes. I taught the MSF course for five years and I did the braking demos because my partner didn't like doing them. I taught for the Navy and used my bike for the class (a sportser and a superglide). One of the things I discovered in the old "controlling rear wheel skid" excercise was that if I used both brakes I had a hard time locking up the rear wheel. In the "maximum braking excercise" I used both brakes as hard as I could and the bike just stopped. It is my personal opinion that both brakes are there for a reason and while most of the braking power is applied to the front, in order to safely stop I need to follow the rules of using both brakes, head and eyes up and knees against the tank.
Old May 9, 2008 | 09:08 AM
  #66
Rob2002's Avatar
Rob2002
Lots of good advise here.
I did it within the first week I had the new EGC. Now I know where that point is and have not done it since but it happens. Even to good riders. Did I consider selling the bike as suggested above? Yea right.................
It is pretty hard to practice a panic stop without the panic but I'll grab a bunch of brake at a couple stop signs on the way home from work just to keep my feel for the system.
Old Mar 14, 2009 | 09:07 PM
  #67
nine11c2's Avatar
nine11c2
Originally Posted by Wtxflhtx
If your locking up the rear brake on a heavy bike I sugest you go to school and learn not to stomp the brake. Better yet sell the scooter before you get hurt.
People learn to ride first not ride to learn
I've seen three of four quotes like this. I've ridden for years on a Dyna's and Softails and non Harley's and have almost never locked up a back brake. I rode my friends Ultra Classic 20 miles and locked the rear brake twice. My buddy, who has a Sportster choper, a Nightrain and just bought a Street Glide, and is a good rider, locked up the rear wheel when basically normally slowing for a turn and ran off the road. Its happened to him as many times in 2000 miles on the Street Glide as it has in tens of thousands of miles with the other bikes. The tourer rear brakes lock easily. I think its a matter of the weight distibution of the bike (you sit forward and upgright compared to other bikes).
Rider experience would be if we're talking about riding all types of bikes - face it you tourer bigots - there actually can be something wrong with them. Listen to what experienced riders are telling you - in many, typically single up situations, probably OE Dunlops, etc. the rears are much more touchy than any other bike.
Old Mar 14, 2009 | 09:10 PM
  #68
nine11c2's Avatar
nine11c2
sorry, fat fingers..
Old Mar 14, 2009 | 09:17 PM
  #69
GT_RoadGlide's Avatar
GT_RoadGlide
I have only locked up the rear brake a couple of times unintentionally in 40 years of riding. I do, at the beginning of every riding season, lockup the rear tire on wet pavement. This gives me an idea of how much lever force I can exert before the tires locks up. I do this exercise around 30mph in an area with no traffic.
I always use front first followed by rear. Panic stops are really unsettleing.
Old Mar 14, 2009 | 09:28 PM
  #70
Beemervet's Avatar
Beemervet
Is a "tourer bigot" the opposite of "tourer ignorant'?
