removing Tach on flhrpi
Old May 6, 2008 | 09:56 PM
sportyrider1's Avatar
sportyrider1
Default removing Tach on flhrpi
OK I am pleading ignorant on how to disconnect tach from police RK. is there a plug and where is it located? do I have to remove my handle bar clamp cover or go into the headlight?
Thanks
Old May 6, 2008 | 10:21 PM
Medicfrost's Avatar
Medicfrost
Default RE: removing Tach on flhrpi
Removing a tach from an FLHP-I (FLHRPI isn'tan actualmodel)is pretty easy. Remove your headlight and trim ring, and right behind it is a few wiring harnesses. Find a harness with 3 wires coming out of it, and disconnect it, replace your headlight, and you're done. To completely remove the tach, you can remove the riser cover, and you may be able to slip it through, but if you cannot, you'll need to remove the entire nacelle, and trim. A good site to see other tips related to police bikes is www.flhpi.com
Old May 6, 2008 | 10:45 PM
sportyrider1
Thanks I thought flhp was the electraglide model and flhrpi was the roadking version. mater of fact I believe my title says flhrpiI will have to look, anyway thanks for the info I am adding a faring to my bike so the tach has to go for now
Old May 7, 2008 | 12:40 AM
dawg's Avatar
dawg
ORIGINAL: sportyrider1
That would beFLHTPI. FLHPI is road king police
Old May 7, 2008 | 08:22 AM
twincam47's Avatar
twincam47
ORIGINAL: dawg
On all 2007 and newer Tourers including the Police models.....the "I" was dropped from all designations...."I" was for fuel injected....Now it is just FLHP, FLHTP and FLHPE. The "E" in the last designation is for a California Compliant Police Roadking.
SmittyFXDL
Apr 8, 2016 08:05 AM
jeffreyjames
Mar 5, 2012 08:10 PM
bigskyhd
May 14, 2008 01:51 PM
kevdog
Feb 19, 2008 11:00 AM
tlmmotorsports
Jul 22, 2007 11:39 AM
