race tuner vs PCMIII?
Had the PCIII for my 08 ultra classic, kept dying. Sent it back 2 weeks later put on the new one still dying. Then i had the dealer put in the SERT works great. want to put in on the dyno next week and see what I get. Will keep you posted!
Now if you want to change just the pipes to make it loader you do not have to do anything.
If you do a stage 1 and change pipes and AC you will need to
1. do a download this will make the bike run with the changes but will not change fuel mix
Bike will pickup some HP
2. do the downlaod and add a race tuner this will make it run and change fuel mix to make it run a bit cooler and add more HP
3.Use the TFI tuner you will not need to any download no dyno time you will change fuel mix and pick up HP. Only down side to the TFI is it is not as flexable as some of the othetr race tuners. Upside it has less problems and easy to use. Tfi can be removed quickly if bike needs to go in for warranty work
4. any heat issues are mostly related to idle while nothing to worry about you can add a simple N02 IED for about 80 dollars it goes between o2 sesnor and fools the o2 sensor at idle and chnage fuel mix to enrich it there by cooling the bike. It has NO effect at any other time on the bike.
easy to install and no danger of damaging 02 sensor as you do not have to remove the senor to install
IF YOU DO A STAGE 1 you will need to at least do a download other wise the bike may run too lean.
Do not buy a fuel manage aka race tuner off ebay then blame HD because you bike runs like crap.
I will repeat you do not have to do any of this to make your run or to save your bike. It will run just fine stock
good luck enjoy your bike filetr out the BS from fact and make sure bubba the back yard hd expert keeps his hand off your bike
the cause of 98% of all HD problems
Morning Rerb95
RJ
Harleyglideman....Thanks a million for the advice and I apologize in advance for any inconvience I may have caused by reposting... I have looked through the previous posts....
Has anything or anyones opinion changed on this?
Thanks again! and I'm truly sorry!
RJ
